No_hair_left
- Joined
- Nov 2, 2023
- Messages
- 203
- Likes
- 75
I'm currently running an r2 meta and some q4 metas as left and right, happy enough with them but am thinking of switching to the arendal 1961 monitors as an lcr, am I mental?
I only have 7 inches to work with depth and with the arendals I can make it a 5 base layer of say 3 monitor x 2 bookshelf's as they have vesa 100 mounts, I cant really make q4 meta for sides work as they are too big.
I never go above -30 on my avr so spl is not an issue and my left and right seats will be within 20 degrees so I don't think the mtm design will actually effect me as I'm only 7ft away.
Not a lot of options in the uk for on walls other than the m&k sound mp750 but one of those as a center looks even more compromised, don't even know what design that is and there are no measurements for them.
Had some dalis before that and they are far too bright and I much prefer the thinner looking speakers aesthetics wise, only other option was ascendo the 6 narrow but it looks like they struggle to get lower then 110hz which is too high for an lcr for me.
Another option seems to be the xtz on walls, its tweeter is raised so not sure if that solves or causes problems, https://xtzsound.eu/en/series/inwall-inceiling/xtz-inwall-onwall-e-iw62/p/mqzvuqtm2, not sure if this is classed as an mtm still?
