Disclaimer first:
I work for Lewitt.
Don't ask me to help you set up the headphones though - I work in R&D, not in customer support
I don't think I'll add this to the repository - it is already tuned to hit the target as close as is reasonably possible. Any further adjustment will be based not on the average but on the individual - that's not something I can help with in an EQ preset.
We expect people need to adjust:
- the bass, which mostly depends on how well the headphone seals against the user's head (people with glasses and/or long hair will need to turn the bass up)
- the high frequencies - this partly depends on the shape of your ear canal and partly on the amount of hearing loss you have (if you're over 30 then you most likely will have some hearing loss at high frequencies)
- Low-mids (200-300-400 Hz) - on some people where the earpads don't fully seal there's an additional resonance at around 300 Hz, they might need to reduce that with the EQ
- Upper mids (3 kHz) - at the ear canal resonance we notice some variation across different users. This again is expected for a closed-back headphone. Users may need to increase or decrease this region by maybe 2-3 dB
For all of the above, the headphone by default is tuned to fit the average user (no glasses, no long hair), so if that's you (no glasses, no long hair on the side of the head) then chances are the stock tuning will fit you well and you'll only have to adjust for personal preference.
These questions all revolve around the same topic:
On our test panel there's:
- men and women
- different hair length (bald, short hair, medium hair, very long hair)
- different beard length (shaven, stubble, full glory)
- different ear sizes (from very small to annoyingly large - seriously, our CTO hurts his ears on basically every pair of headphones, that's how big they are. But it also means that if they fit him, they'll fit virtually everyone)
- with and without glasses
- different ages
- different ethnicity
We can't account for everything, but within the limitations set we got a representative test panel here.
We did test the headphone on people with glasses as well, yes, so we can quantify how much bass is lost on average with/without glasses. Making the LW6 more leakage tolerant than other closed back headphones was a design goal - and we can prove that we achieved it
I'll definitely publish an EQ setting that compensates for the average amount of bass lost when wearing glasses!
Indeed! That's why we relied much more in real-ear tests (microphone in real ear) than on test fixture tests (e.g. Gras 45CA or B&K 5128) for the acoustic tuning of the headphone.
It can be quite tricky if the DSP limits the amount of filter bands you have - you then need to get creative with overlapping filters instead if just throwing peak filters at the graph and let the optimizer adjust gain, frequency and Q-factor.
I did work on the tuning, but it's not "my" headphone - it's the work of everyone who worked at Lewitt in the past years. Two ex-Focal engineers did the driver design and part of the electronics, An ex-Sennheiser engineer worked on acoustics design as well. It was quite the team effort!
I haven't tested them on the PS5!
But these headphones go much louder than conventional wireless headphones - they're classified as professional headphones, not consumer headphones, which means they are not subject to the 110 dB limitation of consumer headsets. The max SPL is just over
120 dB on the LW6 - so loudness will not be an issue on them even if the PS5 cuts the volume in half for some reason.
The headphones have a loudness guard feature where they will automatically reduce volume if the sound pressure exceeds a certain value (value can be set by the user, the feature can also be deactivated if you want to break your eardrums. Not recommended). And yes, the headphones do show the current SPL in the app (peak and RMS) so you can check how loud you're currently listening. It's accurate to within about 3 dB.
