Level-Matched Headphone Target Curve Shootout on an iPhone Using EffectDeck
HeartByte
I’ve always been curious about which headphone target curve would suit my preferences best. But with limited time and no easy way to do this on my iPhone, I’d never got around to properly comparing them.
Enter EffectDeck!
EffectDeck makes it practical to experiment with headphone EQ entirely on an iPhone, with system-wide PEQ and support for AUv3 audio plugins. Its integration with EffeTune’s Analog Meter Analyzer also made it straightforward to level-match different EQ profiles for my shootout.
My setup
  • Headphones: Sennheiser HD560S
  • Source: USB-C iPhone
  • DAC: Neutron HiFi DAC V1
  • Music: Tidal, using tracks from my downloaded “Best Of” playlist
  • EQ: EffectDeck, with EffeTune’s Analog Meter Analyzer plugin
My SenseLab Aizu EffectDeck chain for the shootout, showing the preamp Volume effect, EQ, post-EQ Volume effect for loudness adjustment, and Analog Meter used to compare loudness readings for level-matching the profiles.
The shootout: 10 profiles, 9 target-curves
I tried these 10 profiles, with Harman represented by two implementations:
  1. Oratory1990 Harman
  2. RTINGS Diffuse Field
  3. RTINGS
  4. SenseLab Aizu
  5. SoundGuys Consumer
  6. SoundGuys Studio
  7. ToneBoosters Morphit Studio
  8. ToneBoosters Morphit Harman
  9. ToneBoosters Morphit HiFi
  10. ToneBoosters Morphit Commute
This is a good starting point if you want to explore different headphone tunings. You can find profiles on RTINGS EQ Repository, Oratory1990’s PEQ presets and ToneBoosters Morphit.
How I level-matched them
I played the same YouTube pink-noise signal, for around 30 seconds or so per profile, until it settled and used EffeTune’s Analog Meter Analyzer in Loudness mode to compare the Integrated loudness readings.
SoundGuys Consumer gave me the lowest reading, so I used it as my baseline and manually reduced the post-EQ output gain of the other profiles until their readings matched.
The important thing for me was that I could do all of this on my iPhone, without needing a PC or a complicated measurement setup.
My results
SenseLab Aizu was my favourite overall.
I particularly liked its tonal balance and the perceived spatial depth of the presentation. Oratory1990 Harman made vocals seem more prominent to me, while RTINGS sounded more balanced. RTINGS Diffuse Field was too bright and thin for my taste, while SoundGuys Consumer sounded bassier and muddier by comparison. The Morphit profiles offered interesting alternatives, with differences in perceived bass, treble and vocal prominence.
These are subjective impressions from sighted listening, not an objective ranking of the target curves. Your own preference may be completely different.
Give it a try!
The main takeaway is that exploring different headphone tunings doesn’t have to be a complicated desktop project. With EffectDeck, system-wide PEQ, AUv3 plugin support and a convenient way to level-match profiles, I found it easy to run this experiment entirely on my iPhone.
If you’re interested in headphone EQ, I’d recommend trying profiles from Oratory1990, RTINGS and ToneBoosters Morphit. Level-match them as carefully as you can, listen to music you know well, and see which tuning you actually prefer.
Have you tried any of these profiles or other target curve profiles on the HD560S or other headphones? I’d be interested to hear which ones work best for you.
Links
I’ve been looking for something like this for a long time. The Chat GPT assistance didn’t work smoothly for me though, generating a link that didn’t work. But when I asked it to provide JSON text to copy and paste, that worked.
For my HD6xx, I also preferred the SenseLab Aizu target to both Harman (which is the only other EQ that I tried) and raw dogging.
I was very surprised to find out I preferred Aizu because I’ve been playing around with these profiles for some time now and never leaned towards Aizu before. I think the level matching and an easy way to switch between all of the profiles during a single testing session were the ingredients I was missing and EffectDeck enabled that for me.
There is also another effect that I discovered only yesterday when I was getting this article ready. It’s called IR Reverb and there is a guide on the EffectDeck website : https://effectdeck.nemut.ai/guide/brir
I had used convolution before and it never sounded good to me until now. Not sure if I can ever go back to listening without it:
I added an aizu peq before the IR Reverb and my AKG K371 never sounded better.
Weirdly on my hd560s I liked the ir without eq but both impressed me.
I have created my own adaptation of the Aizu 2026 target response for IEMs, both for the B&K 5128 and for 711 clone couplers. I recalculated the averages and produced a complete extrapolation from the data points published by SenseLab. I further reduced the highs to comply with the research done by Harman on the B&K 5128, because the Aizu target overshot the highs on basically 100% of the models tested and sounded very glary (you shouldn't EQ the highs anyway; this was just part of my experiment). I also made a very subtle adjustment to the bass based on SoundGuy's target, given the heightened preference for bass in IEs compared to OEs.
All in all, using them for IEMs, you can expect to find the same effects that you find in OEs: an ear-gain that is wider and starts later, which makes the sound considerably more relaxed and, in a way, distant. In my tests with Aizu applied to the K702, the HE400SE and the HD 550, you can get IEMs to sound relatively close to them with these few changes. Not exactly the same, but close enough. The general feeling of a thick, restrained, fatigue-free tuning is achieved.
I only tested the targets with the Hangout, Earphone Archive and Super Review repositories in Squig. I don't know how they would work outside of that.
Here are some interesting comparisons (this curve was modeled completely independently without referencing any specific IEM):
Thanks for sharing that.
I would like to try it on my hd560s headphones and also my truthear zero and possibly my kiwi ears quintet. I assume it's possible to use on both headphones and iems ?
Also what would be the right way to load this? - I'm thinking SuperReview for 711 and one of the other 2 you mentioned for the 5128 ?
I also wonder if loading in peqdb.com would work as it includes measurements from all of the three you mentioned and I could then average the hangout and EA 5128 measurements for example before eqing the avg to the curve ? I can experiment with this if/when I get some time but asking in case you already know if it's possible to load/use the target files on peqdb.com or not.
Thanks
No, it is adapted for IEMs. It will probably sound dull and bassy on OE. Just use the original one for OEs. I wouldn't expect much from this in over-ears.
These are my modifications for IEMs from the 2026 Aizu extrapolated target I recalculated.
Exactly.
Don't average measurements from different couplers.
No idea, sorry.
Btw, Symfonium offers a binaural virtualization that is more customizable and less colored than other alternatives, in my opinion.
It's also very easy to load PEQ profiles in it.
Thanks for the suggestion. I've heard about it and I wanted to give it a try eventually but I don't think it's a streaming app is it ? I've completely moved away from local files just this year and I'm likely never going back otherwise I'd still be using Neutron on my iPhone :).
No, it's just a player. I only use local files.
I like it a lot!
The 711 loaded into peqdb.com fine and I’m using that one now and initial impressions after a few level matched comparisons with harman, soundguys consumer, aizu, moondrop vdsf and some listening is that it’s right up there with my favourites.
That’s what it looks like loaded on peqdb.com vs the crinacle zero averaged from all sources on the site. I know averaging over different fixtures is not a good idea but I think for iems those are likely all on 711 couse the diffs seem very small to me and the avg then matches some of the samples very well.
It may very well become my go to for iems now tbh. I feel it creates a nice musical atmosphere, a little on the warm side but I don’t feel like I’m losing too much in the highs. Very relaxing listen.
Thanks again, I appreciate it!
The
I like it a lot!
My target is specifically calibrated for Super Review, Mark Ryan uses a particular compensation in his Squig, it won't translate well to other measurements. Try using it with his Squig, it will perform much better.
Either the direct one or the one I created comparing the measurements from the 5128 with 46 different IEMs measured by him.
It won't translate well to other couplers, I promise. You will like it more if you use his Squig. He has measured the Quintet and the Truthear Zero.
Also, the calibration above 6 kHz is not reliable at all. Just EQ below that for the most part. Except if you want a very broad filter high. But don't touch the little peaks and valleys, it will sound bad.
You can also directly use The Hangout measurements, which are done with the 5128, so no translation is needed.
PD: I think I prefer the original one over the one using 46 IEMs as a reference, btw. More data is not always better, I guess.
I would use the SuperReview Squig but it does not have a treble safe eq option like others do for that high shelf needed in the treble past 6k and in general squig does not work well for me and I use it only as a last resort. For example even on Mark’s, though the settings say to use shelf as well as peak, it only ever does peaks and it’s not the only squig that does that.
I like peqdb because of the functionality and that it brings in measurements from multiple sources including Mark and Hangout for ex.
It does a treble safe eq on standard and can also do precise but like you say, eqing the little peaks past 6k is not good so I use the standard 10 band and it also uses shelves correctly as opposed to squig. For ex this is my quintet peq to your first 711 you shared:
Preamp: -3.6 dB
Filter 1: ON LSC Fc 81 Hz Gain -2.45 dB Q 0.458
Filter 2: ON PK Fc 237 Hz Gain -3.22 dB Q 0.980
Filter 3: ON PK Fc 257 Hz Gain 3.84 dB Q 0.629
Filter 4: ON PK Fc 3265 Hz Gain -5.52 dB Q 0.973
Filter 5: ON PK Fc 3790 Hz Gain 4.04 dB Q 1.771
Filter 6: ON HSC Fc 6108 Hz Gain 6.54 dB Q 0.520
Filter 7: ON PK Fc 6134 Hz Gain 2.73 dB Q 2.518
Filter 8: ON PK Fc 8278 Hz Gain 2.20 dB Q 1.530
Filter 9: ON PK Fc 9265 Hz Gain -2.87 dB Q 3.168
Filter 10: ON PK Fc 14933 Hz Gain -15.40 dB Q 0.462
I also see little difference between the 711 and the second 46iems 711 one:
Also Marks measurement and the average I used look very close as well:
And the. the standard peq profile on the average using the 711 looks to have been done in that treble safe manner:
I donno… all looks quite good to me and sounds good too, so no complaints from me :)
You can adjust it manually in Squig.
Looking at the PEQ profile your auto-generator produced in peqdb, there are a few severe acoustic and digital issues you should be aware of:
Your preamp is set to -3.6 dB, but Filter 6 (HSC at 6.1 kHz with +6.54 dB) and Filter 7 (PK at 6.1 kHz with +2.73 dB) sum up to more than +9 dB of digital boost around 6.1 kHz. You are exceeding 0 dBFS by more than +5.5 dB, which will cause severe digital clipping on any modern master unless an internal limiter is crushing your dynamics. Your preamp would need to be at least -9.5 dB to prevent clipping with those filters.
The Kiwi Ears Quintet already has a micro-planar and a PZT (piezoelectric) driver that are quite energetic in the presence and lower treble regions. The "treble safe" algorithm on peqdb actually injected +9.2 dB at 6.1 kHz and another +2.2 dB at 8.2 kHz, before cutting 15 kHz by -15.4 dB. That is the opposite of a smooth roll-off; it will accentuate metallic glare and sibilance.
Notice Filters 2 & 3: one cuts -3.2 dB at 237 Hz and the other boosts +3.8 dB at 257 Hz (just 20 Hz apart). The same happens with Filters 4 & 5 at ~3.5 kHz. The automated optimizer is placing opposing filters right next to each other. While they cancel out in magnitude, they introduce unnecessary phase and group delay anomalies in the fundamental vocal range.
peqdb.com scrapes raw files; it does not account for Mark Ryan's dynamic browser compensation (IEF 2023 Cal), and averaging multiple reviewers who use different insertion depths and rig tolerances washes out the acoustic transfer function. Also, loading the 5128 target into a 711 database will compress the visual scaling, but they represent entirely different acoustic impedance planes.
If you like the sound right now, it's mostly because pulling down that 3.2 kHz region (Filter 4) is doing the heavy lifting of relieving your ear fatigue. But if you want to hear what the curve actually sounds like without digital clipping or fighting filters, try generating an EQ locked strictly below 6 kHz (with a manual broad shelf if needed), or at leash manually set a proper negative preamp to avoid the +9 dB overload in the highs!
Beyond the filter issues, I would strongly advise against using peqdb.com as an EQ engine altogether. The site’s automated optimizer is notoriously unconstrained: it lacks basic regularization to prevent fighting biquads, has a broken headroom algorithm that ignores cumulative shelf gain, and blindly scrapes uncalibrated raw data from disparate rigs.
If you want a reliable, automated web interface that works well on mobile without Squiglink's clunky touchscreen UI, use Jaakko Pasanen’s official autoeq.app instead. Both Jaakko on the algorithmic side and Mark Ryan on the measurement side (with his disciplined curation, insertion protocol, and calibration on Squiglink) do things with actual metrological rigor. Jaakko's tool respects proper smoothing, enforces minimum-phase stability, and won't feed your DAC a clipped signal. Otherwise, manual PEQ in Mark's Squiglink or directly using 5128 measurements remains far safer than trusting peqdb's backend.
SuperReview Squig autoeq to 6khz puts a -3.3 preamp or up to 15khz it puts -4.6 and peqdb -3.6. If I load the peqdb one into superreview squig and then export, it re-calculates the preamp to approx -1.3 so I don’t think it needs more especially since once applied it does not result in such high peaks as you were saying:
And if I import it i to crinacle’s eq tool, it also calculates preamp to -1.2:
So I think -3.6 is actually more than needed and should be fine.
My understanding is that preamp depends on the combined fr of all the peq filters and not the largest single boost and with the optimizer doing things that might be hard for a person to gauge the effect of, applying it and checking the results is the way to verify it. Looks ok to me…
Yeah, you're right. It was late and my calculations regarding the PreAmp were completely off. Sorry.
Using a bit more negative pre-amp would not hurt because of possible ISO due to the filtering and seeing most DACs perform slightly better just under 0dBFS but that's another discussion.
I already use apple music with soundcheck on(with playlists) and that already does normalization, apparently to -16 LUFS for individual tracks which from what I've seen, means a gain reduction and not raising it. I've not seen any clipping even with orchestral music so far and I've yet to find a track that naturally clips. If I have any doubts, I can always add a level meter on an effectdeck chain and see if it clips.
Also my understanding is that in the digital domain, it won't clip unless you raise gain over 0 dbfs somewhere in your chain, because inter sample peaking should already have been accounted for during mastering of the track as that is apparently the standard way to avoid inter-sample peaks and digital clipping. While in the analog domain, it wouldn't be an issue unless I had a current bottleneck driving the headphones or iems. So far I've only found this is a possibility on my Sundara 32 ohm 92 dbspl/mw when used with my qudelix 5k which is then current saturated and can only drive it without clipping technically to a Saturation ceiling: 115.23 dB SPL. This is the main reason I built my own power calculator for the qudelix and Fiio dacs: https://pockethifiguide.heartbyte.website/#calculator
The problem here is the word should. Sadly not all mastering is properly done.
Also ISP are not an issue ISO can be. How audible this is depends on the DAC and duration amongst other things.
As soon as on uses signal processing new ISP (and thus also ISO) can occur.
Adding a bit more than needed negative pre-amp before the processing can help.
Thanks, I think you've convinced me to add another one or two dbs of gain reduction to my chains. What's another 1 or 2 to the -9 or so from soundcheck, up to -10 from PEQ, and -15 from IR reverb with brir :)
