Try harderThe best I could get out of the Kamado was 280-300.
And sure, for a wok (and pizza), it’s a compromise, but I’m not going to get a specialist tool for everything.
I must say, personally I do not care how much power my gear consumes... what I do care about is whether it runs warm/hot or reasonably cool.
Which is why USAnian food - though tasty - mainly consists of fried-stuff-with-cheese**-and-extra-meat.I take no cooking advice from Brits, Dutch, or Germans.
Do you have it on a time switch so you can pre-arrange to get it hot in time for tea next Tuesday?We have a kettle -- quite a nice one, given to us by our daughter.
You forgot the colours, preservatives, bleach and hormonesWhich is why USAnian food - though tasty - mainly consists of fried-stuff-with-cheese**-and-extra-meat.
**and you have no idea what cheese is either
Do you have it on a time switch so you can pre-arrange to get it hot in time for tea next Tuesday?![]()
You forget, real kettles sit on top of the gas or solid fuelled stoves that are doing their stuff baking fresh scones and bread to go with our afternoon tea. None of those imitation plasticky electric things thanks, let alone that stodgy white sludge that passes for bread.![]()
I don't really care that much about the power consumption of my amplifiers either, especially since I have a RTX3090 computer standing just next to it, but I still find the discussion about the efficiency in power draw to be interesting. And I really don't think there is much to discuss when it comes to heat, size and weight of class D vs AB, you just have to look at them and the answer is there.I must say, personally I do not care how much power my gear consumes... what I do care about is whether it runs warm/hot or reasonably cool.
The electricity used by audio gear is so minimal compared to things like A/C, water heaters, refrigerators etc., it's really not worth worrying about from an annual usage perspective. If members are concerned about their overall power usage, best to focus on efficiencies in these types of devices and household insulation etc. rather than audio equipment.
The thread was originally about the efficiency of amps, class D types in particular, in comparison to others... not really about the overall power consumption itself, that wasn't really the point.
JSmith
The large burner on my regular gas stove does fine for wok cooking 95% of the time, good enough for when weather doesn't allow me to do it outside on my wok stand. But the flame is absolutely necessary.Try harderI have little issue getting it to 400+ C. Didn’t have much luck with pizza at those temps though. It needs quite a bit of tweaking, but I’ll figure it out eventually.
I have a DCS professional gas stove (the previous house owner was a chef) and a 120 v induction hot plate.Induction has been awesome for us. We had gas for forever (originally a Viking). I never thought I would give it up. We got an induction hot plate and that was that. It’s like cooking with turbo gas but no flames. Practically magic!
There are kettles and then there are kettles. Good ones here in Blighty are 3KW rated, others can be not much more than half of that, how many Watts from the 120V ones?I have a DCS professional gas stove (the previous house owner was a chef) and a 120 v induction hot plate.
The hot plate can boil water faster. Simple physics. Nearly all the energy is transferred to the water.
I’ve used a British 230v kettle. It was not appreciably faster than my 120v version. Both Krupps.
Technically & officially, at least in the US and, as I recall, other major markets (Europe, Japan, China), fuel economy (e.g. MPG on the window sticker) is measured with the car stationary. It's placed on a dyno in a lab and a "driver" runs it through a cycle of various speeds/loads/etc. Same thing with an engine oil labeled energy conserving is evaluated in a lab, on an engine - dyno stand and run through a variety of speeds/loads/temps/etc and compared to a baseline oil.And that's where the debate is misleading. In other tech areas efficiency is normally evaluated at normal workloads. Do you see car designers publishing fuel consumption when cars are running stationery?
Of course I understand in a home environment amps are often running at low volumes, but if people want to use a 2x 400W class D amp for that then that's their own choice. What pma's measurements show is that such an amp effectively is more efficient for more than 90% of its output range. And that's why the title of this topic could be more nuanced.
This is like the LED bulbs that advertise 17 year lifetimes, and last 2-6 years in actual use. But you wouldn’t have to test home stereos for years. A month would do.Technically & officially, at least in the US and, as I recall, other major markets (Europe, Japan, China), fuel economy (e.g. MPG on the window sticker) is measured with the car stationary. It's placed on a dyno in a lab and a "driver" runs it through a cycle of various speeds/loads/etc. Same thing with an engine oil labeled energy conserving is evaluated in a lab, on an engine - dyno stand and run through a variety of speeds/loads/temps/etc and compared to a baseline oil.
English is not my native language. What I meant with stationary is the engine running at idle speed (which in Dutch is referred to as 'stationair toerental'). A fuel consumption test is performed on a dyno, but it is a dynamic test including accelerations and max speed to 131km/h. The narrative of this thread is, aerodynamic cars are not more efficient because I never drive faster then 30km/h.
Explain how vehicle fuel economy testing is like LED bulbs as there is no connection AFAIK.This is like the LED bulbs that advertise 17 year lifetimes, and last 2-6 years in actual use. But you wouldn’t have to test home stereos for years. A month would do.
You are exactly right. People are looking at idle consumption and saying they often don't use more than that and the higher efficiency at higher power does not concern them. It is false because at times people do use high power where class AB is inefficient. Also false because several measurements of idle power in class D amps have been provided and conventional AB amps often maybe generally draw more idle current. So class D is slightly more efficient at idle and much more efficient as power use climbs. The thread title is an error.English is not my native language. What I meant with stationary is the engine running at idle speed (which in Dutch is referred to as 'stationair toerental'). A fuel consumption test is performed on a dyno, but it is a dynamic test including accelerations and max speed to 131km/h. The narrative of this thread is, aerodynamic cars are not more efficient because I never drive faster then 30km/h.
Testing fuel economy or light bulb lifespan in a laboratory is useful for comparing products against each other, but it doesn’t tell you what you will get in real life. Although fuel economy testing is much better than it use to be.Explain how vehicle fuel economy testing is like LED bulbs as there is no connection AFAIK.
Man Alive! It would be so effective and cool if we had a power or current and voltage measurement at the time of a ASR test unloaded and loaded.You are exactly right. People are looking at idle consumption and saying they often don't use more than that and the higher efficiency at higher power does not concern them. It is false because at times people do use high power where class AB is inefficient. Also false because several measurements of idle power in class D amps have been provided and conventional AB amps often maybe generally draw more idle current. So class D is slightly more efficient at idle and much more efficient as power use climbs. The thread title is an error.
