olds1959special
My living room setup:
I betcha just some big, BIG sound in that room. Nicely done. Neat and tidy except for a few cablesSharing the journeyView attachment 496508View attachment 496509
I’m not sure about the drift correction. At first I thought it sounded better without using it at all but then one day I played music and the speakers were very out of sync. So I the end I just decided to use my Apogee Duet center setup as my main interface and set the MiniDSP to drift correction. I assume the center speaker naturally has less delay anyway.Thank you again for your participations!
Now I am much interested in "drift correction" between your DAC1 and DAC2 especially how you can also achieve the "trigger synchronization" between the two when you start playing a music track.
Do you have common word clock synchronization mechanism between the two?
Or are you applying Mac OS's quasi-sync-aggregation functionality among multiple DC units?
Just for my curiosity, on Windows OS with ASIO and/or WDM/WASAPI drivers, I rather intensively tested/evaluated whether strict "trigger synchronization" would be achieved or not among multiple independent DAC units each has its own ASIO (or WDM/WASAPI) drivers.
I found the trigger timings would be dependent on Windows audio handling priority, and hence perfect/strict "trigger synchronization" cannot be achieved by audio handling/routing software tools like ASIO4ALL and VB-AUDIO MATRIX (ref. #783, #804 and #1,021 on my project thread).
Of course, we can perfectly sync the multichannel DAC processing including the triggers in case if we use "multichannel DAC unit" like 8-Ch OKTO DAC8PRO which I use throughout my project having its own multichannel ASIO driver.
to avoid bigger problems with drift correction, I used my miniDSP as the main device and use the drift correction on the Duet 3 which only goes to the center speaker/subwoofer. I can't detect a delay.Thank you again for your participations!
I found the trigger timings would be dependent on Windows audio handling priority, and hence perfect/strict "trigger synchronization" cannot be achieved by audio handling/routing software tools like ASIO4ALL and VB-AUDIO MATRIX (ref. #783-"Summary Fig.18", #804-"Summary Fig.20" and #1,021 on my project thread).
Of course, we can perfectly sync the multichannel DAC processing including the triggers when we use "multichannel DAC unit" like 8-Ch OKTO DAC8PRO which I use throughout my project having its own multichannel ASIO driver.
Drift correction - well there is always something one can learn. How would that help with the measurements, if we for once, ignore the subjective part of the story?to avoid bigger problems with drift correction, I used my miniDSP as the main device and use the drift correction on the Duet 3 which only goes to the center speaker/subwoofer. I can't detect a delay.
I stopped using multiple DAC's and simply plugged the center setup into the MiniDSP outputs. The volume is slightly lower without any extra pre-amp but it's in sync now.Well, I think it would be always a kind of "endless theme" for our discussions, measurements, and subjective listening evaluations.
And I believe we should clearly separate the two points/issues in this regard of multiple-channel DAC processing;
1. trigger (kick-off/start-up) synchronization (or not) among the DAC channels, even if the strict synchronization (drift correction) could be achieved afterwards,
2. clock synchronization = drift correction among the multiple DAC channels after starting/triggering playback of a music track.
I learned a lot about these features/issues through my rather intensive objective measurements (of course, plus subjective listening evaluations) which I shared in #783, #804 and #1,021 on my project thread.
We can completely "solve" both of 1. and 2. by using sync multichannel DAC unit like OKTO DAC8PRO (I use it), TOPPING DM7, all-new MOTU 16A, etc. all of which have dedicated multichannel USB ASIO driver.
We can also "solve" the issues if we can achieve all synchronized AES/EBU digital inputs into the multichannel DAC (or such multiple DAC units) if they have AES/EBU digital inputs (like OKTO DAC8PRO), since AES/EBU digital signal contains clock sync pulses in it. This has been widely achieved in pro audio market in multichannel recording and sound editing.
Furthermore, even in the case of USB ASIO configuration, we can fully synchronize certain "same brand" multiple DAC units (like RME Fireface UFX III) if they have some "sync trigger and drift correction" mechanism with each other through their dedicated USB ASIO driver (ref. #842 on my project thread). In the case, each of the multiple DAC units needs to be connected to USB ports of PC (or Mac) so that the ASIO driver can recognize all the sync-aggregated DAC channels.
I seldom listen louder than 85-90db but the image and soundstage of the system is huge.I betcha just some big, BIG sound in that room. Nicely done. Neat and tidy except for a few cables![]()
yes I still enjoy playing LPs despite my pro earsHello @Sjkrabbe,
Thank you and welcome to this exciting thread!
Very nice to see and learn your setup photos and total signal path diagram.
I can well understand how much you enjoy listening to your LPs using two TTs, and I am very much impressed you are actually a professional sound engineer enjoying vinyl listening at home...![]()
The on-going process in Copenhagen. Latest development in my living room - New Room Correction: Oria Mini - New BluRay/DVD/CD/Media player: TASCAM BD-MP1MKII - DAC for the Tascam: TOPPING E30View attachment 512865
