You can. Use software to increase the dynamic range. But it's time-consuming, difficult, and lazy. It's easier to just not listen.If there is a way to make badly mastered music listenable in better quality, we should use it.
We are talking about intersample overs in this thread, not loudness compression...You can. Use software to increase the dynamic range. But it's time-consuming, difficult, and lazy. It's easier to just not listen.
Intersample overs are part of the problem with loudness compression, and eliminating them alone won't help.We are talking about intersample overs in this thread, not loudness compression...
No, loudness compression is not related to loudness normalization. Two completely separate topics.Intersample overs are part of the problem with loudness compression, and eliminating them alone won't help.
You cannot remove a loudness compression during playback. No way. Unfortunately.You can. Use software to increase the dynamic range. But it's time-consuming, difficult, and lazy. It's easier to just not listen.
Be careful, some of them have a digitally controlled volume after the DAC, so that would make no difference. And some use an ASRC as volume control, and these are generally very sensitive to inter-sample overs.You don't necessarily need to buy a DAC that mitigates intersample overs internally as long as the DAC has adjustable output volume.
Yikes! That's interesting to know, thanks. Do you know of any examples?Be careful, some of them have a digitally controlled volume after the DAC, so that would make no difference. And some use an ASRC as volume control, and these are generally very sensitive to inter-sample overs.
| Intersample-overs tests Bandwidth of the THD+N measurements is 20Hz - 96kHz | 5512.5 Hz sine, Peak = +0.69dBFS | 7350 Hz sine, Peak = +1.25dBFS | 11025 Hz sine, Peak = +3.0dBFS |
| Teac VRDS-20 | -30.7dB | -26.6dB | -17.6dB |
| Yamaha CD-1 | -84.6dB | -84.9dB | -78.1dB |
| Denon DCD-900NE | -34.2dB | -27.1dB | -19.1dB |
| Denon DCD-SA1 | -33.6dB | -27.6dB | -18.3dB |
| Onkyo C-733 | -88.3dB | -40.4dB | -21.2dB |
| Denon DCD-3560 | -30.2dB | -24.7dB | -17.4dB |
| Myryad Z210 | -70.6dB (noise dominated) | -71.1dB (noise dominated) | -29.4dB (H3 dominated) |
| Sony CDP-X333ES | -30.5dB | -24.8dB | -16.3dB |
| BARCO-EMT 982 | -32.7dB | -24.5dB | -16.3dB |
| TASCAM CD-200 | -73.5dB | -36.3dB | -19.7dB |
| Sony CDP-597 | -30.4dB | -24.7dB | -16.5dB |
| SMSL PL100 | -53.1dB | -31dB | -19.1dB |
| OPPO BDP-95 | -39dB | -28.8dB | -19.2dB |
| OPPO BDP-95 (vol -2dB) | -95dB | -97.5dB | -32.7dB |
| SMSL PL200 | -94.8dB | -97dB | -39.5dB |
| SMSL PL200 (vol -1dB) | -94.8dB | -97dB | -58.7dB |
Or am I completely wrong in assuming that such an analysis would be useful for Streamer-DACs?
Why Fixate on SINAD if an DAC with SIAND over 96dB can be bought for less money then a CD.I still struggle to understand the fixation with how different DACs handle edge cases that may happen for a few milliseconds per track at most.
If you record typical pop radio music for 24 hours straight, for how many minutes do you think the digital waveform is above 0dBFS in that time frame?This "edge cases" happen in the real world with Real CDs and in real Popular music That people actually listening to... (Unlike 1kHz sine waves from the SINAD test)
So i would not call this a edge cases.
If you record Audiophile classic music for 24 hours straight, for how many minutes do you think the digital waveform is pure 1khz seine wave in that time frame?If you record typical pop radio music for 24 hours straight, for how many minutes do you think the digital waveform is above 0dBFS in that time frame?
Why Would you divert from DAC to AMP? And there are plenty Cheap DACs that don't have a Noises problem.a noisy Amp
Who in this thread said anything about 1kHz SINAD? I didn't that's for sure. Strawman much?If you record Audiophile classic music for 24 hours straight, for how many minutes do you think the digital waveform is pure 1khz seine wave in that time frame?
I'm not trying to divert, I'm trying to refocus on things that have actual, tangible, consistent effect on listening experience.Why Would you divert from DAC to AMP? And there are plenty Cheap DACs that don't have a Noises problem.
So it can be considered a solved problem for all realistic purposes. even in some of the cheap models.
So how would you measure and rank DACs? The standard ranking here seams to be 1kHz SINADWho in this thread said anything about 1kHz SINAD?
And if you would stay on the topic of DACs and not divert to to AMPs this argument is invalid since,I'm trying to refocus on things that have actual, tangible, consistent effect on listening experience.
I wouldn't.So how would you measure and rank DACs? The standard ranking here seams to be 1kHz SINAD
I would, unless you can demonstrate otherwise. And to do that -- for predicting audibility -- you must take the density of ISOs into account.Why Fixate on SINAD if an DAC with SIAND over 96dB can be bought for less money then a CD.
I'd wager <1 minute, which would equal 0.04s or 10-50% of the time it takes to blink, per minute of playback .
