I completely disagree!
This is a problem the affects nearly half of all CD-format recordings.
Archimago recently analyzed 31,400 tracks in his personal music library. 44% contained peaks exceeding 0 dBFS.
Please see:
Archimago's Musings - August 9, 2025
He found that he needed the following amounts of DSP headroom the play 99% of the tracks in each of the following genres:
Classical +0.79dB
Soundtracks +1.70dB
Vocals +1.82dB
Country +1.89dB
Hard Rock/Metal +2.03dB
Classic & Progressive Rock +2.35dB
Jazz & Blues +2.42dB
Pop +2.87dB
Rap / Hip-Hop +3.08dB
Electronica +4.22dB
The dynamic range of most DACs now exceeds what is usable in most listening situations. If the peak SPL at the listening position is 115 dB, then any DAC with a 115 dB or better dynamic range will not produce any audible noise at the listening position (assuming the DAC is properly gain staged to the power amplifier). If we allocate 3 dB to headroom, then we would need a DAC with a 117 dB or better dynamic range. A large portion of the DACs tested by Amir exceed this dynamic range requirement.
Trading a few dB of dynamic range to eliminate hard DSP overload clipping is a good tradeoff.
As things stand now, most DACs cannot properly play 44% of the CD tracks that are in Archimago's library. One reader scanned 11,588 tracks and found similar results.
The sad truth is that most DACs cannot properly play nearly half of all CD-format recordings. Many DACs have far more dynamic range than needed, and some of this should be traded off to provide headroom above 0 dBFS.
The biggest problem is that Archimago is about the only person testing DACs for digital headroom.
Amir needs to get on board with this test if this site is going to continue to be a go-to site for DAC reviews.
