So now I have measured the analog RCA output of my Topping E70, which was fed from Wiim ultra WITHOUT resampling. So unlike my previous measurement (
#621) where I explicitly tested the perfromance of resampling of the Wiim Ultra under the stress of intersample peaks, I am now testing the performance of the Topping E70 DAC. In that previous post I have already shown in the very first plot the signals with intersample peaks are perfectly transmitted using the digital SPDIF connection, so this will now really only test the DAC's performance.
I am testing the RCA outputs of the DAC with an Audtient ID24, where I use the Insert Returns, which completly skips the pre-amp of the Auditent and thus has the highest SNR I can get with this device. The SNR should be at 120dB.
I have tested the RCA outputs at both the 2V and 2.5V setting, the restults are absolutely identical. I will show the 2.5V results here. I have not tested the XLR outputs because the ADC of the Audient ID24 peaks at +12.5dBu (=3.26V) which is not enough to measure the the XLR outputs, but is plenty to measure even the 2.5V RCA signal.
Let's start off with a baseline, measuring 0dbFS (first the 5512.5, then 7350 and finally 11025, all at 0dBFS):
View attachment 427551View attachment 427552
Ok so I measuere an THD+N of around 90dB. I don't know where my bottleneck is, it could be the AudientID24 which has less then expected SNR. But it does not matter here, since what we are after are complete breakdowns of the transmission.
So now let's look at our intersample peaks (same sorting as above, each at its own maximum volume, 5512.5 @+0.69dBFS, 7350 @+1.25dBFS, 11025 @+3.01dBFS):
Here we have THD+N values of -39, -29,-19 respectively for the 5512.5, 7350 and 11025Hz tones. What is however really interesting and actually unexpected for me, we don't have the spectra of clipping here! Clipping would produce only uneven harmonics. But here the 2nd harmonic is also always there, and is almost as loud as the 3rd. That is actually important for this discussion!
Now I tested at which setting the volume knob of the Topping E70 DAC the spectra normalize:
- -0.5dB for 5512.5
- -1.0 for 7350
- -3.0 for 11025
Thus the volume setting on the Topping E70 does prevent the issue, and apparently the device has some headroom, since the it needed only -0.5dB for the +0.69dBFS singal and -1.0 for the +1.25dBFS signal. To further test that I made a series of files where I took the 5512.5Hz file and decreased the volume by a small amount. The result is that the Topping E70 has somthing between 0.26 and 0.29 db of headroom. I need a better test to quantify that more exactly.
