VientoB
Can Chord DACs handle inter-sample overs?
The Mojo2 can handle +1dBFS, but not +3dBFS: https://goldensound.audio/wp-content/uploads/2022/05/USB-Isolated.pdfCan Chord DACs handle inter-sample overs?
Some some improvements people might feel they can hear with the M-scaler could just be the inter-sample overs being cleaned upThe Mojo2 can handle +1dBFS, but not +3dBFS: https://goldensound.audio/wp-content/uploads/2022/05/USB-Isolated.pdf
The M-Scaler reduces all incoming signals by about 2.8dB, so improves intersample over performance of all DACs plugged into it, at the cost of less volume:
https://goldensound.audio/2022/03/17/chord-hugo-m-scaler-measurements-and-technical-evaluation/
That's all I could find.
I have yet to see proof that intersample overs are an actual, audible issue.Some some improvements people might feel they can hear with the M-scaler could just be the inter-sample overs being cleaned up
Hmm. Digital clipping can certainly be heard. But I suppose clipping of such short duration perhaps not?I have yet to see proof that intersample overs are an actual, audible issue.
Is there a list of these songs, or examples?John Siau at Benchmark can hear a brightness resulting from distortion, with some songs having hundreds of examples of this phenomena. I suspect that those that came on here claiming that their DAC sounded bright, only to be told that noise/distortion was below the threshold of hearing and they're imagining it, were probably right. It depends on the recording. Kinda looks like all these 'transparent' DACs might sound a bit rough sometimes.
Is there any ABX on this you can point to?brightness resulting from distortion, with some songs having hundreds of examples of this phenomena.
You can always actively create you own proof, as this can be analytically tested with little effort, see my post earlier in this thread.Is there any ABX on this you can point to?
www.audiosciencereview.com
It couldnt be that John Siau is imagining it?John Siau at Benchmark can hear a brightness resulting from distortion, with some songs having hundreds of examples of this phenomena. I suspect that those that came on here claiming that their DAC sounded bright, only to be told that noise/distortion was below the threshold of hearing and they're imagining it, were probably right. It depends on the recording. Kinda looks like all these 'transparent' DACs might sound a bit rough sometimes.
What are "wrap-arounds"?You can always actively create you own proof, as this can be analytically tested with little effort, see my post earlier in this thread.
My aging ears can hardly hear a difference between IS-over reproduced faithfully and properly clipped IS-overs but that doesn't mean anything what is audible to others.
What I still do hear is IS-overs causing wrap-arounds, though.
When the output reaches a certain level where it would normally clip, it goes to the opposite polarity, full scale, rather than simple saturating.What are "wrap-arounds"?
This shows "wrap-arounds" of computer integer arithmetic when we have overflows (or underflows when dealing with negative numbers). The upper panel is the Python code, the lower shows the output.What are "wrap-arounds"?
The result is a rather loud "click" because it goes from full positive output voltage to full negative (or vice versa).
DAC chips normally don't do this, but it can happen in digital pre-processing like sample rate converters or other stuff. Some older YAMAHA CD-players had a dithering chip (for use with digital volume control) that extended the 16-bit data to 20-bit which caused these nasty wraparounds when reaching full scale values.
But you came to the conclusion that it's an Android software issue, with DAC chip proper innocent, didn't you?Here's a modern (albeit cheap) consumer DAC that will hit the opposite side when presented with intersample peaks. I don't think we should assume DACs with this defect are rare.
From a Rob Watts post:The Mojo2 can handle +1dBFS, but not +3dBFS: https://goldensound.audio/wp-content/uploads/2022/05/USB-Isolated.pdf
So according to him intersample-overs can only happen during recording (or downsampling too, I guess)? That's some new definition I've never seen before.
Read it again, that's not what he is saying.So according to him intersample-overs can happen only during recording (or downsampling too, I guess)? That's some new definition I've never seen before.
