TNT
- Joined
- Jun 24, 2020
- Messages
- 387
- Likes
- 274
What measurement did you do to come to this conclusion.I thought it would make a difference, but obviously I can't measure that benefit
Cool. Shouldn't one also look what is going on close to DC. Your charts all ends at 20Hz... or much higher. But then one must realise that it takes a really good measurement system to investigate this or the results are swamped by it. I have a suspicion that nasty things are going on in the sub Hz region...I'd be interested in testing such a word clock
That said, and this is why I created the little table to show the difference between the LEO BODNAR and the SMSL G1, as the later shows 30dB better attenuation at 1Hz. I thought it would make a difference, but obviously I can't measure that benefit. So, at the moment, I guess -70dBc at 1Hz is more than sufficient to get the benefits I measured.
Now, like I said, I'd love testing another DAC with a clock input to check if the same benefits repeat the same way.
