- Thread Starter
- #21
Probably one in ZurichWhich McDonalds are you frequenting?
Thanks and good idea!That was an interesting test, thank you!
Any chance you could run a multi tone test as well? I wonder if that might show any differences / improvements?
I was reading your test of the SMSL D200. Not unusually, it seemed to get a bit mushy at low frequencies.
I'd be interested in testing such a word clockFor audio, the stability aspect is of no real use. How long term stability affects audio is that Rubinsteins piano play A (440Hz) today, but also 50 years from now.
What could be usable is a really low close-in phase noise - that would mean that the presented graph should read -120dBc instead of -70dBc at 1Hz.
Thank you!The two trace are the same. The LEO BODNAR does not improve things here.
That's why it was a good idea to suggestThank you!
I thought that because you measured slightly less spreading on the foot of the 1kHz fundamental with the TEAC when zoomed in to a 1kHz span, that you might see similar improvement at the lower freque3ncies with the multitone where a few Hz might make a difference.
But as you say, no, that's not the cause or the solution. Thank you for trying.
Maybe you could try the AP multitone with No FFT Window...Thanks and good idea!
Here you go, the common parameters are:
- SMSL D200 variable pre mode, volume set at 0dB (5Vrms output max)
- 48kHz sample rate
- Multitone 1/10 decade @-10dBFS RMS (-0.49dBFS pk)
- FFT length 1M, 32 averages, BlackMan-Harris 7 window, 93.75% max overlap
Not exactly.with multitone, the noise floor is more elevate
You have to have an FFT windowMaybe you could try the AP multitone with No FFT Window...
Since you are asking, and I am in a playful mood:So which DACs have an external clock input that could take advantage of this thing? I know there are some, but it isn’t a common feature.
That's why I specified -10dBFS RMS for both.Not exactly.
The single frequency peaks are actually lower.
Because crest factor is much higher.
Also, and probably for that reason, you say you run it at -10dBFS.
So basically they should make a premium version in a fancy box to compliment that sort of DAC.Since you are asking and I am in a playful mood:
That was the first brand that came to mind...
- dCS Vivaldi APEX DAC: around $46,500 to $48,800 USD.
- dCS Rossini APEX DAC: around $32,800 to $34,500 USD.
- dCS Lina Network DAC: Taround $14,400 USD.
since this $155 would work as well as their:
- dCS Lina Master Clock: Around $8,150 USD
- dCS Rossini Master Clock: Around $12,100 USD
- dCS Vivaldi Master Clock: Around $24,100 USD
Sorry I could not resist ..
The dCS Vivaldi clock accepts an external reference, such as one generated by a GPS receiverSince you are asking and I am in a playful mood:
You don't.You have to have an FFT window![]()
Well, dCS has a pro gear background so I’ll give them a pass on this—but not on their pricing.Since you are asking and I am in a playful mood:
Oh, ok, so I understand you're not a REW's user.You don't.
But it may be called "rectangle" or whatever else.
The AP multitone is optimized for lowest crest factor and each tone is in the middle of an FFT bin.
PLEASE don't .. They did start in Pro, but devolved into a money grabbing outfit...Snake Oil purveyor.Well, dCS has a pro gear background so I’ll give them a pass on this—but not on their pricing.
Agreed. There's no justification for their pricing.PLEASE don't .. They did start in Pro, but devolved into a money grabbing outfit...Snake Oil purveyor.
Where do you live... I thought that would be 15 usd...$155: About the price of a McDonald's Big Mac Meal
It's not a matter of which tool you're using.Oh, ok, so I understand you're not a REW's user.
Rectangular window generates too much leakage and is not adapted, especially from a signal not created by REW's generator
I run the MT test of REW with "Minimise crest factor" set.
The AP test file can't be used with Rectangular window, too much leakage:
