- Joined
- Jan 5, 2024
- Messages
- 72
- Likes
- 27
I know that there are several threads on "whether all amps sound the same" and although some of the technical discussions go over my head, the impression I'm getting is an amplifier should not color the sound provided that it has flat frequency response. In other words, if you're comparing amp A to amp B at the same power wattage, and both are flat in the audible range, there should not be any coloration to the frequency response such as less bass or more treble, etc.
I was recently looking at Amir's review of the Buckeye NC252PM and saw the following graph. My naive question is... is this an example of where an amp will in fact color the sound? Or is increasing distortion not related to audible sound quality? Another related question is... if max power at 20hz is 122 watts, and if you happen to listen to a lot of music that plays that low at loud enough volumes to require 122 watts (probably not a common scenario, but let's just assume this for the sake of argument), then for all intents and purposes, shouldn't this be rated 122 W at 4ohm, as opposed to the 250 W at 4ohm spec?
