Leaked Capacitor or Glue?
Martini
I'm in the process of updated an old VGA projector in a training room and will need to update the audio interface as well. We're making the big step up to digital & HDMI :rolleyes: Anyway, I thought I would give a visual check of the amplifier that is in the room. It's a QSC 302V, which I think if from the early 2000s. The Gain pots are a little noisy, but there were no bulging caps or burnt/overheated looking components. However, one cap looked a little questionable to me, as I wasn't sure if this was previous leakage (as it's hardened) or sloppily glued. No other caps in the unit are glued.
Looks like glue to me - esp. the upper part. A leak would rather stay down I guess.
If other caps (this size or larger) aren't glued, it is slightly strange though...
The top of the cap is bulging up. If I were me (and I think I am) I'd replace it. It's a cheap part...
They use a glue gun and it can be messy!
Dead easy to change the cap though - as said, it looks a bit 'bulgy' on top.
That was what raised question marks for me. It is a separate board though, so perhaps a different practice by that assembly person.
No, not bulging, just a deceptive picture.
Or a previously repaired /replaced board.
If it's a board put on its side (with the glue looking the upper side), is kind of an old, sane practice, kind like a habit, as this cap is too small to cause any trouble.
(these blue ELNAs seem to be immortal, I measured a bunch of them salvaged from an ancient all-in-one SONY "stereo" out of curiosity and not of one of them was out of spec)
Just glue. Having recapped dozens of devices I oftently found stuff exactly looking like that.
