Lavry Gold Savitr (new A/D standalone)
Officially, at 12p.m. and 1am I will be a year older. That, of course has no meaning in the physical world. J.W. Gibbs explained observation in 1899. The reality is that “you can’t do anything in zero time”. Say the goal is to change from 0 to 1 a “clean” 90-degree step. The real-world outcome starts at 0, but it takes time to “clime up” (rise time). The signal passes 1.00 and “climbs” to 1.09 (9% overshoot) the first cycle of decayed ringing. 1KHz or 1GHz bandwidth it is always around 9%. The ringing frequency is bandwidth cutoff frequency. The decay is hyperbolic v= Sin(w*t)/t (multiply by 1/t).
Sine waves: A simple single step is enough to bring up that sine wave (sinusoidal). Nature is full of waves, harmonic behavior made out of “elements”. Much of sound contains harmonic energy, more so for music instruments designed to generate harmonics.
One can reduce the impact of Gibbs phenomena and all signal continuities with “windowing”, rounding the sharp corners. One more time, the sine wave shape shows up in constructing the windows.
We should know by now that much of sound energy (air vibration and music energy in particular can be viewed as made out of “components”, each component is defined by frequency, amplitude and phase. Simple addition of the “components” is the same as the “original”.
That is the fundamental idea behind audio testing, to measure how the device behaves when encountered by each sine wave component. If it behaves well for a tone, it will do so for music. But music does not behave like a constant frequency tone. Two or more “unrelated” sine wave components are used to probe possible intermodulation distortions, (should be under the noise floor). For example, a -12dB 7KHz “riding” on 0dB 60Hz yields a constantly changing wave. We know that the tones should not interact, and where to look for distortions.
Sine wave-based testing is the way to test audio (like Audio Precision) My job, as a designer and a manufacturer is to ensure that the AD can accommodate all possible music by checking cases, how the unit treats all the components. Clearly “all” cases are not practical, but say 100 frequencies from 20-20KHz, spaced linearly or logarithmically. Or say -100-point plot of 0dB-120dB level change…
I read opinions that a system based on sine waves can’t test “real music”. I am all for good listening tests (set up properly). But “exercising” a converter with various music in a quite facility is a “big deal”. It takes time attention, and “operator” and two or more good ears to listen different music tracks say all in agreement. But with music the information is “soft”. There is always a question about listening to enough variety and more.
The test system can force, measure and quantify all that is needed. For example, a full-scale tone at 20KHz or more. If the AD operating correctly for such tone, it will behave well when 20KHz is 5th harmonic of 4KHz, or 4th harmonic of 5KHz… The system enables probing the complete range of human hearing using sine wave tones and combinations.
Again, audio testing with sine waves and combinations enables probing the whole range of the components that make up the signal (music). Separating the sound into components (such as fundamental and harmonics, phase, flatness response). It enables separation of parameters such as amplitude-frequency, THD+N, noise…
I lot of people don’t believe in measurements due to little specification details or other reasons. I understand that a product for the ear should be evaluated by the ear. I design for the ear. Needless to say I am very glad when some tests my AD with an Audio Precision. I am very pleased when successful pro audio people use my AD to spread good music around the world. Needless to say there is a lot more to AD design for for use in professional studio environment.
Back to my birthday and Gibbs: It is almost 10p.m. I need to start ramping up to be at 50% at 12p.m. I hope the pace maker does not ring at 2a.m tomorrow.
Send one sample to Amir and all's fine.
Happy birthday!
Latency, Bandwidth, 44.1KHz and the “drum kick”:
My last post was about the Gibbs phenomena. A drum kick, Electric guitar and more can produce a fast-changing waveform. A real fast “transient” (not my vocabulary but common expression) will generate up to 9% overshoot (maximum theoretical value) followed by ringing at the bandwidth cutoff, decaying in time.
Humans hearing may be limited to 20KHz, my golden ear friends insisted that that they can “hear above 20KHz”. They talked about listening to drums “smear”, “un-natural” or “poor transient" and "hearing above audio". Indeed, the math and looking at Gibbs phenomena seem to indicate that extending the bandwidth to say 40KHz is needed to maintain linear phase to accomplish “correct audio” (remove pre-ringing).
AD converters operate at higher sample rate (oversampling) with the final stage (decimation) requiring requiring a low pass digital filter around 20KHz.
Linear phase filter: using FIR for a more accurate conversion, but the pre-ringing energy issue remains. FIR filter is phase linear. A long FIR means increased LATENCY but offers better results (it starts the pre-ringing earlier, but the ringing impacts is not improved).
Minimum phase filter: analog filters can be emulated in digital. An appropriate IIR filter can “deal” with the ringing. It postpones the ringing until after the transient (no more pre ringing). Even better, it can decay the ringing fast (thus the phase impact on music). Such filters are associated with low latency.
That advantage comes at a cost. The nonlinear phase distortions (typically above 10KHz) alters the waveform. Another drawback is the amplitude response, little drop at 15Khz, up to a few dB at 20KHz.
I was glad to design 96KHz converter but there is a lot of music in 44.1KHz. A “sharp” filter yields flat frequency response and the correct waveform shape for audio.
I don’t hear it, but I understand it. There is a choice to be made, you can't have linear phase and no pre-ringing
The Savitr AD offers linear phase conversion with very low latency (471uS/44.1KHz, 249uS/96KHz, 130uS/192KHz). This is good enough even for overdubbing, while maintaining flat response and waveshape.
The AD offers a low latency mode. (153uSec/44.1KHz, 103uS/96KHz, 86uS at 192KHz). Small contribution to overall delay is welcome, but using that mode is for pre ringing and the old Gibbs phenomena issue. The low latency filters are often referred in audio to as “gradual filters”.
It is easy to switch on/off in real time between “normal” and “low latency” mode. I did what I can, this is truly a decision for the ear.
It is worth noting that in some studio and recording work, low latency is sometimes a critical requirement*. Domestically, unless you are trying to synchronise with video, higher latency tends to be less of an issue. It's a bit annoying if you have to wait a couple of seconds after pressing play thanks to million-tap FIR, but it's not that bad an inconvenience.
* There has been something of a revival of all-analogue studio chains, using analogue mixing consoles in recording studios. Digital consoles have all sorts of benefits, but they do increase end-to-end latency which can affect some creative work.
The Gibbs phenomena shows that a “quick step” it can be electric guitar, drum or whatever will generate “extra energy” a 9% peak for any bandwidth, followed by ringing you can’t hear directly but impact the hearing range by “destroying” that phase relationship of the harmonics.
This is all about bandwidth and not about digital or analog. Most analog gear can offer over 40KHz bandwidth to have minimal phase impact on audio. NO such flexibility for converters (bandwidth is about half the sample rate).
One way to tell by ear is to switch between say 44.1KHz and 96KHz. If you hear the problem (pre ringing) at 44.1KHz, there is an option to shift the pre-ringing to start after the “drum kick”, and decay the ringing fast. Setting to low latency will sound more “old analog”. The filter is digital but low latency is emulating an analog filter and all the compromises involved, amplitude loss at higher frequencies and phase misalignment resulting in altered wave shape.
Using an analog filter for limiting to 20KHz does introduce phase distortions. The most common filter configuration is the Bessel filter, often used in DA anti imaging. I heard and read the common reason, that Bessel filter offers linear phase. But BESSEL FILTER IS NOT LINEAR PHASE, not even close.
I am not commenting about electro mechanics (mic, speaker and headphones), it is not may area. Analog electronics can offer the bandwidth, the word communicates using digital. Converter are often the bottle neck. The phase distortion impacts lower frequencies, and the music itself matters. I wanted 60KHz sampling, the world moved to higher. That is another story,
I'm happy to be corrected, but I think that's incorrect.
The Gibbs phenomenon happens wherever there is a non-infinite bandwidth. It's therefore a function of the air in the room where the acoustic guitar is plucked or the kick drum is struck. It's also in the microphone. It's also in the microphone preamplifier. It's in the mixing desk channel and the power amplifiers driving the monitor speakers. It's in the monitor speakers. It's in the ear of the mixing engineer. There are therefore hundreds of overlapping Gibbs phenomenon happening when the note is plucked or the drum is struck. Probably the dominant "ring" is caused by whatever thing has the least bandwidth.
If we have no electronics and I'm in the room where the string is struck, the air is not the limiting factor. Depending on the note, it's quite possible that the instrument has the lowest bandwidth in which case the Gibbs phenomenon is a natural part of how I perceive it's timbre. Such "ringing* existed for Pythagoras, way before microphones, amplifiers or ADCs. If the note is much higher, at my advanced years, it's possible that my hearing has the least bandwidth and so the Gibbs phenomenon will be inside me.
What do you disagree with?
I stated that I don't talk about speakers or mic. Yes gibbs phenomena happen whenever there is bandwidth limit, which is ALWAYS. The question is audibility of the Gibbs phenomena0
Ll
L
L
I was talking about the AUDIBILITY of Gibbs in relationship to music recording and processing.
Audibility has do with bandwidth. At higher bandwidth (say 96KH conversion, 48KHz bandwidth, the phase distortion casing audible impact are negligible (phase is pretty linear).
I stay in my lane, I am not talking about the instruments, only about the electronics, where it is not just a concept, but applies to my work. The math is the same for all bandwidth limits, but there are some way to deal with it to a large extent.
The Savitr offers a low latancy mode. I don't know what speakers, mics, or any others do.
My post was aimed to explain some detail about the relationship between latancy (phase alteration) and the pre ringing.
Gibbs always happen, but with higher electronic bandwidth it does not impact the audio.
I will try to explain better:
I agree, Gibbs phenomena are everywhere because there is always bandwidth limiting. But we are talking about different things.
My post was about pre-ringing due to Gibbs. Pre ringing does not happen when you pluck acoustic guitar or hit a drum. The string does not move before you pluck it.
Similarly, analog electronics does not react to a signal before it happened. Gibbs phenomena are always there, and one can reduce audibility by increasing bandwidth. But there is no pre-ringing. It is a digital filter issue, in relation to Gibbs phenomena.
Increasing the bandwidth is not always an option (44.1KHz or 48KHz sampling). For converters there is a need to filter a signal. Filtering similar to analog (emulation) means direct phase distortions in the audio band. Analog filters (and digital emulation of such) are “minimum phase”, low latency. The behavior will be closer to an 20KHz analog limitation.
The direct phase distortions due to bandwidth limitation can be overcome with digital processing (FIR filter). It requires some latency, but offers phase linear conversion. The issue here is the Gibbs “peak and ringing” begins BEFORE a fast signal occurs. People describe the effect differently when they hear it.
Digital filtering offers perfect linear phase conversion; analog filtering does not. But there is a compromise. Analog filter can not introduce pre ringing, but the cost is some attenuation of high frequency amplitude and altered waveform.
The Savitr provides a choice between Normal and Low latency. It should make it easier to decide, much of it depends on the music.
I also think about “drums and Gibbs”. I don’t deal with mechanical vibrations and the bandwidth associated with it.
The post aimed at a very specific issue. To make it short:
Converters may impose bandwidth limits. (20KHz at 44.1KHz).
Two ways to filter in digital: linear phase with some latency and possible pre-ringing or removal of the ringing at the expanse of amplitude flatness and wave shape alteration.
Converting at 96KHz does not eliminate Gibbs. I don’t think it is audible at such bandwidth. There is little to be gain at 192KHz.
I can offer a choice, normal or low latency. I leave the decisions about such compromise to the ears.
To continue, a bit more detail:
The pre-ringing issue, some called it pre-echo, smeared and more happens in digital processing, not in analog or digital interpretation of analog behavior.
Analog processing is “real time”. Digital processing offers incredible power: the music samples can be stored in memory, recalled, marched in time to the drum beats of a high frequency clock… That enables viewing some history of the signals many samples back. That costs some delay (latency) but all that information enables perfect amplitude response and phase linearity (correct wave-shape).
The down side: the previous samples with the same "history" that helps "fix everything" introduces some pre-ringing, a characteristic of the filter.
Analog and digital are like day and night. I lived it designing ADs for 50 years. Even on a conceptual level, a capacitor current yields the voltage by 90 degrees! Inductor voltage leads the current by 90 degrees! There is no 75 degrees capacitor. Digital is free from such basic components behavior limitations I am simplifying, but it is worth noting that with analog, amplitude alteration may involve phase distortions. Digital processing is not limited by the same considerations.
Just to be precise, conceptually, a “bucket brigade” such as a series of “sample and hold” (alternating odd and even) could make a linear phase analog filter. This is of course not very likely to happen soon...
Where I think I disagree is I do not believe the Gibbs phenomenon intrinsically leads to "pre-ringing".
The Gibbs phenomenon is experienced when a string is struck in a room where the instrument has a bandwidth less than infinity; where the atmosphere has a bandwidth less than infinity and where my ears have a bandwidth less than infinity. This is NOT pre-ringing. The fundamental frequency of the "ring" is determined by whichever has the lowest bandwidth: often the instrument, sometimes people with high frequency hearing loss.
I accept you are staying in your lane discussing only electronics and encoders and decoders. However, the point I think you are missing is that the Gibbs phenomenon is already happening naturally before it gets to the microphone, preamplifier or ADC and that fundamental frequency of the natural Gibbs phenomenon "ring" for many instruments will be much lower than any ADC encoding with a sample frequency of 48kHz. The ring caused by the ADC is simply irrelevant in most cases (including pre-ringing) because it has a fundamental frequency half the sample frequency and so is inaudible in most cases.
How do you explain pre ringing (pre echos)?
I do not hear it with my 81 years old hear. But some respected ears do at 44.1KH, enough not to be ignored as a non issue. They dont hear 20KHz.
I do not hear it with my 81 years old hear. But some respected ears do at 44.1KH, enough not to be ignored as a non issue. (They dont hear 20KHz steady tone).
I am not sure about the way the energy of the FIR filter pre ringing impacts hearing. The "activity" happens BEFORE the "drum hit" because the filter begins the reconstruction of the output before the "main lob".
The earlier time of arrival due to the build up of the signal is an issue at times. I offer a low latancy (minimum phase). It is up to the ears to select modes.
I've never seen scientifically captured, blind-tested with valid p-values evidence that pre-ringing itself is audible at 44 kHz when all other factors and confounders are eliminated.
I'm not defending 44kHz sample rate. It's too low. I'm an Electronic Engineer and was working in studios when CD was released. Professional gear was and is 48kHz, which is tight but more sensible than 44kHz. Something above 60kHz would have been ideal, but in the professional world we were constrained at the time by alignment with video clocks etc.
Interesting, I too thought that 60KHz would be better sample rate for audio.
I wanted the industry to stop at 96KHz and now we have 192KH and even 384KHz, a total "waste of bandwidth" and more.
The 3dB at 20KHz bandwidth is not just for the ear, similar bandwidth for a lot of mics and speakers all may "piles up" the attenuation of the high frequencies.
I did not expect anyone to hear “pre echos” of an FIR at 44.1KHz. But when the third highly respected ears hear an FIR at 20KHz in some situation, all I can do is offer “minimum phase” low latency option.
The low latency is certainly more “analog” with all the phase distortions of the decimation filter.
I heard and read reference to such low pass, the Bessel filter as “linear phase”. It is not. I wonder if you also heard that misinformation.
I see a software plug in “Gold Clip”, offering a software emulation of the Lavry Gold converter.
Funny thing, it only works on the signal peaks. Most of the signal is NOT in the peaks. So a poor AD converter with Gold Clip is still a poor AD converter.
The soft saturation features offered “loudness” at the expanse reduced accuracy over the whole signal range (not just the peaks). A good converter offers little performance degradation. A poor AD will get worse.
Such software may be of value in a DAW. The Savitr features (MX and Soft Sat) are accessible at the AD, often away from DAW.
Dear Dan,
First of all, I want to tell you that I’ve been using the Lavry converter for years.
I completely understand your frustration, especially when you’ve spent your life designing products of exceptional quality.
I also understand why so many very talented people have left the other (very well-known) forum because of the overwhelming number of “annoying” people...
But what I’d like to tell you is that you should try to ignore all the noise surrounding your product, even though I know it’s not easy.
You’ve created the “Ferrari” of audio conversion, no matter what they try to say or prove, and you’ve been doing so for a very long time!
As for me, it’s by far the best-sounding converter I’ve ever used in my more than 30-year career.
What’s frustrating is that there are a lot of people without technical knowledge who are trying to prove something…
They have no technical training, so they make a lot of mistakes when they try to prove or measure something.
I had a discussion with some people using Plugin Doctor, it was completely crazy, so I stopped talking to them.
Many of them don’t even know how to properly use an oscilloscope or an Audio Precision.
In short, what I'm trying to say is that you're much more than just a creator in this field: all your white papers are very informative.
Dan, stop wasting your time trying to explain to them how they should go about it; instead, focus your time on your next product, you're still very young.
Thank you for everything you’ve contributed to the audio industry.
Best regards,
Greg
Dear Dan,
Best regards,
Greg
Hello Greg,
Thank you for your kind words. I am not frustrated about the GoldClip software. The MX (hardware feature) and the Soft Saturation (software) can be turned on or off. It is not up to me to decide if and where the features be used (on recording location, mixing, DAW…).
Assuming the software is good, it only deals with signal peaks. It is not about good or poor conversion. One cannot build an AD or DA in software.
The Savitr AD was my last design. This is my best design. The Savitr offers margins beyond human hearing capabilities. Lavry Engineering is busy since the new AD offers low latency (and some demand to accommodate 192KHz). But I am retired now (81 years old), playing music every day, after 50 years of design (I stopped at 75). Life is good, but what frustrates me is the AI future (and some present) impact on music video and art.
Why bother with microphones, mic pre and AD? And why bother with the instruments, the players and singers vibrating the air? One can start a project in digital, using the AI plagiarizing machine. I think it will cause layoffs and economic hardship on people involved in music production and art in general.
Hello Greg,
Dear Dan,
I wasn't referring specifically to Gold Clip, but to the entire thread.
I fully understand that "Gold Clip" (plugin) is just the final step in a process.
The Savitr is by far the best thing I’ve heard so far today.
I’m glad you’re making the most of life and continuing to make music.
I understand your frustration with AI, but for now, it doesn’t scare me that much, because I use it as a tool (separating tracks, for example, during mastering) and so (I’m more afraid that one day, an AI integrated into a robot will realize that humans are the problem on planet Earth and turn into a Terminator…).
But when it comes to music, I agree with you: it’s frustrating that AI has stolen so much real music to train its capabilities.
I still believe that a good producer, with the right AI, can create incredibly good music (by using it artistically).
On your side, I'm sure you still have plenty of good idea on designing product and I hope to see the future of Lavry Engineering.
Wishing you all the best,
Greg
