1. A typical null test requires just one pass through the loop. Any accumulated noise produced by the loop will be apparent and measurable in the loopback, and this is as it should be. Noise shaping reallocates quantization noise out to (hopefully) less audible frequencies. A null analysis with a loopback will show added noise at those frequencies. Where's the problem? The noise was really added by the conversion at those frequencies, so it should be detected.
2. DeltaWave doesn't require DA/AD synchronization. Synchronization is done by the software to a tiny fraction of a sample. It also measures and removes clock drift if DA and AD clocks are not synchronized. As to the possibility of multiple matches, the software is designed to work with complex music recording, not a simple sine wave. While the possibility of multiple matches is extremely low with any non-digitally generated material, the software will detect this and alert the user should it happen.
It is, of course about the slew rate, the slope as you cross the 0V of a sine wave. The slew rate for full scale tone at 20KHz is around 125000 volts per second. 250000V/S.
Let me try to figure what it would take to design a 100dB hardware test system (far below Audio precision).
For a 1V peak sine wave V= 1* sin(w*t) a tone at -100dB level is 10uV. So an time error for 20KHz is 10uV/125000= 80 pico second
For 40KHz and 80KHz signal it is 40psec and 20psec.
Wow, 20psec is the limit of my test gear for jitter, so far so good, but what about slow time drift? The solution is obvious, an atomic clock. But what about a couple of degree temperature rise… And still there is jitter, usually much higher than 20psec. Pretty easy with a 50GHz computer clock speed, offering 20psec resolution and some real fast laptop of the future. No worry the software will do it. Somehow.
So take two files with some different data, say around 10uV and line them or compensate to 80psec accuracy for 20KHz tone? 2psec to measure 80Khz to 120dB test software? If I could do it in hardware, Elon would pay 100 million…
So the answer is “I do it in software”. A pico second is a millionth of a millionth of a second. Time determination of 80psec based on music that can be off by errors bigger than 10 parts per million.. Music for a long time still has many parts per million errors.
Wow. And all of that while “best fit” is different than correct alignment. I think of it as the pico second bridge.
That test gave my Savitr AD, my best design ever, poor rating. So either the software is broken, or the specific test of my gear was done wrong.
And here we already established that your software as is (without a filter) would consider energy above hearing as a flaw. So the software is already at best limited to 44.1KHz tests. To test 96KHz or 192KHz the user should implement some fantastic low pass filter at 20KHz. What is the point of testing 192KHz with 20KHz low pass? And even at 44.1KHz correcting for 80 psec requires equivalent time resolution of 12.5GHz?
There is more, but let’s put that “difficult to believe” aside for a moment.
I just wanted to see what people say about Savitr. The thing that came out of the search was bad rating. Nothing else, posted years ago. I guessed that anyone doing the same search would lose interest. The people on the thread are not likely customers. We don’t advertise and it is less scientifically oriented group. I was surprised, some guy hated me, I guessed I challenged his buying decision I felt un-welcomed to say the least. And pkane you were one of three leader of the pack, the main one, the guy that wrote the software.
I don’t want to ruin pkane’s day, but he helped ruined mine. He can fix it. I would at the minimum wish the acknowledgment on that gear space thread that either the software is always flawed, or there was some operator error (BIG error), for whatever reason. An apology with clear acknowledgement of the Savitr’s well deserved excellence, strong enough statement to compensate for the years of poor reputation.
I don’t like people reading poor rating on my excellent converter.
