I really like these Larsens, and no, I've not measured them, but after owning them for almost 2 years, I have an itch to try something new. Plus we moved, and I no longer need to have speakers right up on the wall.
(Also on AudioMart) - https://www.usaudiomart.com/details/649631601-larsen-model-62-loudspeaker-mahogany/
I searched for a long time to find speakers that would work in a very narrow room, which forced them to be up against the wall. I was happy to find Larsen, and even happier to find a demo pair. I purchased these Larsen 6.2s from Dr. Vinyl in September 2018.
They performed amazingly well in a difficult room - all hard surfaces, very high ceilings, and only 5' to MLP. I would say they sacrifice imaging for a very wide horizontal and vertical dispersion.
I moved and the new stereo room doesn't need speakers to be against the walls, and I would like something with more bass. I did hesitate to sell these, as they're not very common, but I can't get new speakers unless these get sold.
- left speaker has scratch on the top (see pic)
- no issues, but they were used for mostly background, so they've never been played very loud
- did bi-amp these, but also used my AVR, and for lower level listening, they are quite flexible on amplification
- the grills are hard to keep dust free, but they are in good condition
- I do have the original double boxes, so I can ship them with confidence they'll make it unharmed
Spec's (from Larsen)
Sensitivity 88 db
Impedance 8 ohm
Bass driver 177 mm
Width 230 mm
Height 750 mm
Depth 260 mm
Weight 12,5 kg
Sensitivity 88 db
Impedance 8 ohm
Bass driver 177 mm
Width 230 mm
Height 750 mm
Depth 260 mm
Weight 12,5 kg
