Hi everyone,
Been a long time lurker on this forum and found the advice not only helpful, detailed and accurate, but also considerate. Hoping for some of that here! If I make any obvious errors, for instance if I'm asking this in the wrong sub-forum, please let me know.
I'm starting to treat my room, which has been long overdue, and need some advice when it comes to room measurements. From what I've read, small diaphragm condensers with both an omni polar pattern and calibration file are considered the best for measuring room acoustics, with the UMiK-1 being preferred by many. However, a lot of the discussion seems to be around the response in the high range, as this is where most measurement microphones differ from recording mics. I was wondering if, therefore, a large diaphragm condenser like my Aston Spirit (which has an omni polar pattern) would be sufficient in identifying modal problems. This would be going into my Focusrite Clarett 4Pre USB.
Trying to make my money stretch as much as possible here. I would like to avoid spending £100 on a microphone that I won't use for recording after the room is set up, but at the same time I want to get something that at least shows me where some of the problems lie. £100 saved here would be £100 spent on further treatment, most likely!
The final thing I'd point out is this room is always going to be a mess acoustically: The room measures 4.33m x 4.32m, but along one wall there is a 1.32m x 0.98m cutout for a door. So, basically a square with a chunk out of one corner. There's also another door in the opposite corner, an off centred window on the other side of the room, and the ceiling can't support a cloud (at least, it's bowed and it's come down in another room in the house. Really don't fancy testing the weight tolerance with my head and computer as the measuring stick!). The walls are either 6 inches of brick (external) or sandstone (internal), the only stud wall being the cutout, and I'm on the second story, which I've heard isn't the best for acoustics.
In short, all I want is a rough guess as to where I need to target treatment to make this room as good as it can be, so I feel that spending money on a dedicated microphone would almost be a waste. Agreed, the argument could be made that treating it at all is also a waste, but I felt that if I move into a new room I could at least take the treatment with me and buy a dedicated microphone then when I have the funds to be able to do this properly. Right now I feel that perfection (or what is considered perfection in room acoustics) is so far away, that more treatment would probably go further than a device to show me just how hopeless my mission is!
Thank you for your time,
Jake.
Jake.
