Wendigo79
- Joined
- Apr 27, 2020
- Messages
- 51
- Likes
- 24
I just rearranged my desk and hifi kit near it. Then out of nothing, buzzing and hum appeared on my speakers. I have a Sony Vaio laptop that is connected to a Topping E30 DAC. If i unplug the usb, noise disappears. If i unplug the PSU from laptop and run it by battery, noise disappears. So i think that the problem comes from the laptop PSU. Laptop, amplifier and DAC are all connected to the same power source. Would a galvanic isolator remove the noise? I mean a galvanic isolator that would be located on that usb-outlet that feeds data for DAC. The DAC gets it's power from separate wallwart. I find it odd that the noise started after i rearranged everything. The power source is still the same though. Could my laptop psu be dying? When i squeeze the psu, noise intensifies and tones down in turns. Also touching and turning the psu changes the noise. Perhaps something has gotten loose inside the psu? Unfortunately the psu is type that cannot be opened. I didn't knock it anywhere when rearranging my kit. The problem just started suddenly. Tried to change wallsockets for the laptop and for the dac. No help from that. So I started to think that would galvanic isolator do the trick?
