Lab Gruppen FP 10000Q 4-Ch Amp Clone Review
Rate this amplifier:
    Votes: 74 56.1%
    Votes: 51 38.6%
    Votes: 5 3.8%
    Votes: 2 1.5%
This is a review and detailed measurements of a clone implementation of the Lab Gruppen FP10000Q four channel amplifier. The real one costs about US $2,850. The clone version was kindly send to me by a member and costs around $800.
I get a kick out of them not putting the label in the provided space on the grill! I have not seen the original but this seems like a true clone of it. The unit is surprisingly heavy for a pro amp.
The FP 10000 designation refers to it producing total of 10,000 watts which is kind of amazing given a single 15 amp captive cord:
The fans in the unit howl fairly loudly. And more so if you stress the unit. Large number of gain settings and modes are provided as you see by the array of dip switches. I focused on stereo testing, using Channels A & B and lowest gain of 23 dB.
FP10000Q Amplifier Measurements
As usual, we start with our dashboard:
Don't know what is going with the weaker channel in blue. There are a lot of intermodulation products that don't exist in the other. Averaging both channels, the ranking is very close to poor:
Dynamic range is good though:
Channel separation is not:
Multitone is more reasonable than I expected:
This is some kind of hybrid class AB/Class D design and it shows from frequency response test:
It has no load dependency.
Being so used to these pro amps producing far less power than their spec, I ran the power sweep into 4 ohm. I saw the curve go past 1 killowatt at ease and then bam, everything shut down! It tripped the circuit breaker in my power strip which powered it, the analyzer and my computer. I rebooted and tested just one channel. I saw the power approach 2000 watts now with the same outcome: breaker tripping. So bypassed the power strip and used the AC outlet directly (20 Amp). This allowed me to sweep 4 ohm to clipping:
We are talking 3000 watts total! Granted, this is for a few milliseconds but still, I have never seen such a powerful amp on the bench.
Worried about smoking my dummy load, I limited the sweep for 8 ohm but still got crazy amount of power:
Not sure what happened in one channel.
Next was measuring power at 40 Hz:
No sweat..... But wait. What is that loud fan sound??? A secondary fan had turned on, making the amp sound like a vacuum cleaner. Look at the front panel and the overtemp LED is lit for Channel B. No worries. I let it cool. Sadly, that did nothing. Not only is that indicator stuck on with the fan going nuts, none of the channels work anymore. :(
Man, these amps are no joke. Owner wants to use them to drive DBA subs. If it can be hidden away so the noise is not a problem, you have incredible amount of power for so little money. I wish the thing had come with dual AC connections (for US market). Then you could use all four channels.
Reliability of course is a concern. Is this a true circuit clone of the original? If so, then I say it is not very reliable. But if they have cut corners, then I would think twice about purchasing it based on my experience.
I am torn between recommending and not recommending the FP 10000Q. Let me know what you think.
Thank you for the warning review.
From a purely utilitarian point of view, if a device already has issues out of the box, my last brain cell tells me to avoid it.
It’s not an exact clone. The Learn Electronics Repair channel has a video series on the repair of one of these amps, where he compares some components with the original another clone (edit: corrected after Amir's feedback). (In the video, it was channel D that was broken).
30 years ago we were the Labgruppen dealer for the Benelux (Belgium and The Netherlands), and we used them ourselves in our (extremely large) PA systems and fixed installs untill a few years back (when I left the business). They are very reliable.
The Learn Electronics Repair channel has a video series on the repair of one of these amps, where he compares some components with the original. (In the video, it was channel D that was broken).
The two amps he has are both clones. So we don't know which is closer to the original but true that they are different designs out there.
Please test the real one! We want to now what to expect from a genuine pro amp
As soon as I find $3000 on the street somewhere, will pick that up and purchase one for testing.....
With "Lab Gruppen" in the title I think it would be fair to not recommend a clone, at least until an original has been tested and thus performance of the clone can be judged properly.
And please add the word clone to all instances where you name the company and the product name.
The beauty of pro live sound gear is that you can rent it from local production companies for 1% of the purchase price for a day or two.
I'd love to see some analysis of high end pro gear (amps and speakers) from companies like d&b, Meyer and L'acoustics.
Some 12 odd years ago I purchased one of the 2 channel clone models to drive my DIY subs. The amount of power for the money was absolutely out of this world, but after 1 or 2 years it went out with a bang. No further damage luckily. The noise was also unbearable and the amp had to be installed in a different room.
Since then I purchased a used Powersoft amplifier, and apart from having to clean the pots it's still running perfectly.
Good idea. But, shipping to the US and back will get expensive too. Sourcing them locally = lots of luck I guess.
(corrected - see answers below)
Lab Gruppen is one of the biggest names in pro audio amps worldwide. They have local USA and Canada distributors, and they are heavily used there.
According to their 'About' link, Lab Gruppen is part of the 'Music Tribe' family of companies that includes Behringer.
Given a recent thread addressed to the 'objectivist tribe' of ASR, I chuckled when I saw Lab Gruppen has a link in the upper right corner of their English language site entitled:
'Join the Tribe'
this review amp was NOT a Lap Gruppen amplifier!
Yes,
@Geert was noting a genuinue Lab Gruppen amplifier could be sourced within the USA should one make its way to Amir for measurement.
There are plenty of points of concern:
- Is it legal to clone the Lab Gruppen down to the styling but omitting the name plate? I am not sure.
- The channel mismatch you mention suggests improper manufacturing, e.g. using parts with poor tolerance. I can't imagine a real Lab Gruppen would perform so poorly.
- We don't know what will happen if you bridge the two channels.
- Claims to make 10,000 Watts, but only manages 3000W. Still impressive, but if you claim 10kW I expect 10kW.
- Those noisy fans might be replaceable. I modded my Yamaha and replaced the stock fans with Noctuas, now it is silent unless you stick your head next to it.
For $800, I voted "not terrible". But I am torn between "not terrible" and headless panther. There is no way I would recommend this amp.
Clones, fakes, knock-offs, are in the same bag for me, the one that goes to the trash can.
Lab Gruppen amps can drive trains and they can do it 24/7.
Not this one.
Thanks Amir!
Well, the original claims: 4 × 2500 W @ 2 Ω. We used them at 2 Ω, but I didn't have a the means to do a lab measurement up to 10kW .... We typically used this model with a few channels driving mids and a few channels driving highs so the amp never had to deliver the specified 10 kW continuously. Just common sense, when your job depends on it.
