KZ Angelears Libra X
OK1
Just got mine today. Caveat, of course opinions are subject to change.
Initial thoughts on the KZ Libra X, a collaboration with Angelears, to the best of my knowledge. I will not dwell on packaging and cosmetics, but it has a nice silver coated cable, which just blends in, not calling any attention to itself. My version is the Libra X. There are two earlier versions, the Balanced and High Resolution. Cost of each of these, about $8, definitely less than $10.
1st impressions, a very clear clean sound. Really clear, bright. Listening via a TempoTec Sonata BHD on a Samsung smartphone, with the stock tips (the largest). Clear but bright, a bit harsh depending on the audio source, if there is any hint of harshness or distortion, it shows that up easily. But listening to music that was well mixed without harshness - Imagine - Herbie Hancock and friends, not a single hint of any harshness, just bright.
I feel for the 1st time, the limitation in the number of levels of volume adjustment in the Tempotec, and also on the default volume adjustment in my smartphone. Extremely hard to dial in the right level of loudness. Something that has not really been an issue as much. I've always yearned for finer resolutions in the volume adjustment features of the Dongle DAC and the phone, but now its a bit of a pain, not having this. This IEM is extremely sensitive, it seems to want to respond to every slight change, cos that is immediately audible. Regrettable that I am unable to deliver such fine tuned volume adjustment even with two separate gain "stages" in the audio path. Makes me yearn for the Pro version of my Tempotec, which has many more levels of adjustment - 100 I think.
Then I run against a KZ "feature", inadequate sealing. Very common feature of most KZ's I've owned. And I suspect that the lack of a seal is causing the bass to be inadequate, which is what leave the impression of brightness. Must tip toll.
Replace stock tips with TRI Clarions. And move over to listen on a computer, still via the Tempotec. This brings back some of the missing bass, but also tames some of the high end. Stereo image improves.
Definitely the TRI Clarions - solve some of the concerns. Improving the seal. But I still think this IEM is worth a lot more tip rolling, but I do not have many custom tips. Definitely better with the TRI Clarions, bass is back. But I miss some of that super high end clarity with the stock tips. Definitely a sound I can live with.
With either set of tips I used, these are stunningly clear. Everything is easier to listen to, if a bit lacking in the depth department, just a bit, or quite a bit, compared to the ARTTI T10. I'd say they are balanced bright. Takes to EQ well. Tit EQ - boost bass, drop the highs. Without EQ, will get a bit fatiguing. 1st thoughts were - this would be great for hearing in a call center, but will soon become tiring. After EQ, still remains extremely clear - extremely clear, especially vocals. Subject to EQ, I'd call this the vocal king.
It's a relief NOT to have to deal with channel imbalances, which I tend to have to deal with, in many other IEMs. Turned off all software channel stereo balance settings.
For those doing detailed editing, searching for artefacts, noise, any gremlins in a recording - this would be just the ticket., albeit with the aforementioned EQ enabled. Very easy to listen to at low volumes, cos even with EQ it remains bright and cuts through.
An impressive result, for the price.
Now to comparisons, this was a shock.
It takes a lot of bravery to say this openly. I prefer the EQ adjusted, Clarion tipped Libra X, to the Zero 2.. The Libra X, at this time, in my estimation, is more revealing, and the Zero 2 sounds more congested in the mids. Yeah I've said it. This is a Zero 2 killer, with the stated caveats - Vocals are so much clearer without a sense of distortion I hear in the Zero 2's on vocals. Judging via vocals, which are undeniably clearer on the Libra X, I think the mids on the Libra X are commendable.
The Libra X is so responsive to volume adjustments, You are not hearing something well enough, just turn it up a bit. Yes - with a bit of broad EQ shaping in the highs and lows, and setting the proper volume for the track, this is a remarkable IEM. Smooth when the song is smooth, strident, if the song has strident elements.
It definitely challenges the status quo. The bass is not the most well defined and engaging, (on a bit more listen, I think this is pretty authentic, it is portraying exactly the bass that was in the music), even when turned up, but the mids and highs - remain super clear. Super super clear, especially vocals. Sad about the need to EQ.
I think the bass is about the most accurate I have ever heard, once EQ'd. The difference in the bass, from one track to another, is quite pronounced, leading me to think this is (with EQ,) a very neutral bass. A coloured bass would tar everything with the same brush, making them sound samey. This is the opposite, each bass in each track sounds like a completely different instrument., a unique bass.
Can imagine this would be a good candidate for those who would want to physically mod to improve the frequency response, or practice/learn how to do this.
Let's see how I feel about this in a few months !! Caveat Emptor. I have been known to change my mind.
I bought this set a couple of months ago. 100% agree on the whole fit and seal thing. I replaced the tips with spinfit CP101 I think after knifing off little plastic spots on the nozzle(I think it improved seal a bit)
Ya this is definitely a “diffuse” sounding set. Quite bright and forward sounding but well controlled and smooth treble couldn’t detect any real peaks other than what I assume is canal resonance at the typical 7(ish)khz.
I wish the lower mids and bass were more tilted but other than that fantastic sounding set. Ridiculously ludicrously detailed to my ears.
KZ is basically there. A bass boosted version of this would be v-shaped endgame
Great to hear your opinion of these. The allure of KZ has been trying to find a diamond in the dust. i.e some spectacularly low prized IEM, which performs far above its price bracket.
I ended up over about a year, buying too many KZ's. But nowhere near the number of models they released in the period. KZ/CCA have lots of models and churn out at least one new one every two months.
The general opinion from me is - the low priced IEMs really do not sound good, when compared to better IEMs. Most of the issue, compared to IEM's from other manufacturers, for me, has been :
1. Lack of Clarity
2. Poor manufacturing consistency, such as imbalance between volume levels, between left and right earpieces.
3. The KZ/CCA Sound signature, which in some cases, has far too much treble.
Nevertheless, I have been able to finally arrive at some good picks.
1. The CCA CRA - I think is a decent starter IEM. Not bad for the price., if one gets it at a good discount or on sale @ AliExpress.com
2. The CCA Polaris - is OK, has switched to adjust the bass
3. The KZ EDC Pro - is definitely OK. May not be the most resolving with extreme clarity, but definitely worth the price.
4. The KZ Castor Pro - Harman - just a bit bright, but maybe with adjustment of the switches, it improves a bit. I think the Castor Pro - Bass Enhanced version would be better, but I do not own this. Definitely has a lot of clarity the Harman one, just too bright.
5. The KZ SAGA - Well worth the money, good sounding IEM V-Shape frequency response.
6. The KZ PRX - This has been my best KZ IEM to date, and I absolutely love it, think it is very accurate, balanced, highly resolving, pretty much like a neutral studio monitor. Great in every area, bass, mids, treble, not harsh or sibilant unless that is in the audio. Great fit. I find it an amazing companion to my other best IEM, the ARTTI T10. Both of these have stopped me considering any other IEM purchases. Highly satisfied with both of them, interesting to note that they are both planar magnetic driven IEMs.! The PRX has the better balance and neutrality of the two, with the T10 being a slightly more fun device to listen to. Both are plugged in permanently to my dongle DAC, PRX on unbalanced 3.5mm, with the T10 on balanced 4.4mm. It's a real statement of accomplishment, to admit, for a KZ IEM, I prefer the PRX to the T10, for what I'm seeking, neutral, uncoloured, balanced, clear, transparent. And its well worth the money, for about $35 or less, on AliExpress.com, the PRX represents very good value. That's what I listen to now.
I tend to use the Moondrop SPRING ear tips (best size for me is the XL) for all IEMs, to get the best fit, and most open sound, from top to bottom frequencies.
I like it as a complementary IEM to Truthear Hexa that I don't have to worry about losing. I think it's worth checking out if you want a neutral tuned IEM for dirt cheap. The tuning pushes drums forward. Please don't overpay for this brand, $10-20 is the sweet spot.
You mean I won't get my money's worth paying 80-100 dollars for 12 BAs per side? Isn't more BAs the better?
I think some brands are able to improve the performance over the budget range, using hybrid/multi driver configuration. The Truthear Hexa sounds subjectively better to me than Truthear Red and Truthear Gate(I do wish the Gate was tuned more Libra X).
KZs approach of stuffing in as many BAs as possible and passing it off as premium is questionable.
After trying out a few KZ's there seems to be a pattern. Avoid the real cheapies, such as the KZ EDX Pro X, I'd say also avoid the Libra X, cos it's too bright.
I had a quality issue (level imbalance between earpieces) with one KZ Saga, but the other KZ Saga was fine. That's now my "portable" IEM, sounds great without EQ. In my opinion, a lot of decent sound, and a lot of IEM (metal shell, looks really nice), for the price.
The KZ PRX, remains my main daily driver IEM, which I listen to for several hours each day, when I'm at my desk. Not expensive. Typically less that $35 (£30) on AliExpress, if you search and order search results by price. It has stopped me from bothering to consider any other listening device. Paired with the Moondrop Spring Tips XL, cos my ear canals are on the larger side., superb resolution, balance of highs and lows, clarity, and any other accolade one may give a listening device. To have dethroned an Artti T10, was no mean feat. I still love the T10, but the PRX is more neutral and revealing. Artti T10 has more bass and an attenuated treble, in my opinion, compared to the PRX. The PRX is NOT lacking in bass, but it has wonderful clarity in all frequencies.
KZ Saga and the PRX have been the most balanced, with the PRX clearly on another level, compared to the SAGA. I have no reservations, especially recommending the PRX. Huge achievement in my opinion.
IMO the only overly bright aspect of the Libra X is the upper treble, while the mids and bass seem well-balanced. For typical listening habits, softer music styles or background ambiance rather than focused listening, an elevated bass can help. However, a well-executed neutral tuning could appeal to a good chunk of listeners. This is evident from the continued interest in IEMs like the Dunu Titan S, Truthear Hexa, 7Hz Zero 1 and the discontinued Moondrop Blessing 2 within IEM enthusiast communities.
Reactions: OK1
My Libra X has an imbalance of about 12 dB at frequencies below 500 Hz. The connector on the right earphone has some play. The cable is also of very mediocre quality. I was curious about what ultra-budget headphones are capable of, and I would recommend adding a few more bucks to something proven like zero2 or gate.
Reactions: OK1
I must say I like very much the KZ PRX. But I have same issue that the connector has some play on my KZ PRX, it feels loose. It's 4 month old so quite new but the seller of a big chinese selling platform is not willing to replace it.
I just can recommend to buy on platforms like Amazon, where Amazon is at responsible at least for the shipping, then an exchange is absolutely no problem.
Reactions: OK1
Really sad to hear about connector issues on IEMs, fortunately not experienced this on the PRXs. Had mine for 6 months approx. I hope others can experience them. I use them as my monitors for all listening, and also as my main tool for monitoring as a musician (keyboards and piano), they are most unforgiving, and revealing, a bit too revealing. One aspect is their stereo positioning, I was just comparing to the KZ Saga Balanced version (balanced as in the product variant, not balanced cable) which is still connected using standard unbalanced cabling, and the PRX Stereo placement of stereo sounds like a piano, is so revealing, the Saga sounds almost mono in comparison. Pinpointing the position of sounds in the stereo field on the PRX is the best I have heard so far, on a headworn device., and the sense of spaciousness, to hear the "room" or "room simulation" such as artificial or natural reverb in a recording, is best I have heard in a headworn device.
