KRK Rokit 5G5 Vs KRK 7G5
l3xtown
Please tell me which monitors should I choose KRK 5G5 or KRK 7G5? The main questions are: Does the 7-inch monitor model hiss (make noise) as it was in the KRK 7G4? Is the bass (low frequencies) normal in KRK 5G5? Which ones are better to buy 5 or 7 for a 6x3 room? Will the ADAM T5A/T7A be better than the KRK 5G5/7 G5? Your impressions. Also, please recommend an alternative to these monitors.
Словарь и онлайн перев​
Hi, I've been using the KRK Rokit 7 G5 for about four months.
Here are my answers to your questions:
The built-in amplifier makes some noise.
The bass is about the same as on the G4 — the main difference between the G4 and G5 is in the tweeter. As for the sound modes on the G5, they’re pretty useless — I played around with them after buying the monitors and never touched them again because it’s inconvenient.
Unfortunately, I can’t say anything about how they perform in a 6x3 room.
As for the Adam monitors, I’ve only read about them, but many people note that they have a more accurate sound. Still, it’s best to try and listen to both Adam and KRK yourself.
