Which version? The one designed in 1965, or the one designed in 2020?
There are a lot of
bad recordings out there, however. But, there are
things that you can do to repair some of the damage done. This includes
real-time corrections to mastering EQ issues.
I've never said anything about "golden ears". Perhaps this is important to you? It's not to me. However, like PWK said, the more you listen to the real thing (live acoustic music), the better your hearing typically gets.
Not flawed, but rather typically incomplete, and often missing critical information. The generated early reflections curve from spinorama is a guess only--not measured.
This is basically true with the old Heritage models (Khorn, La Scala, Belle, Cornwall, Heresy) due to issues that were discovered well after they were first designed in the 1940s-1970s. The newer models (especially those time-aligned via DSP)--not so much.
Only if you select a three-way version that you choose to triamp/DSP. If you choose a Jubilee, then you can think of it as using a good HF amplifier and a good subwoofer/bass bin amplifier--low power. These are actually fairly inexpensive, as hi-fi amplifiers go.
I don't know where you got this, but it's wrong. Anyone can multi-amp/DSP correct their loudspeakers.
You do have to set it up right.
Just plopping your loudspeakers into a room without any thought of what the result will be--will get you pretty much what you put into it.
Chris
