Parting / Random Thoughts
As stated in the Foreword, this written review is purposely a cliff’s notes version. For details about the performance (objectively and subjectively) please watch the YouTube video. But a couple quick notes based on my listening and what I see in the data:
- Hi with grille. Something missing in the midrange. Data shows a dip in the lower midrange/midbass transition.
- “Hi” setting is too midrange (upper and lower) heavy. I prefer the mid and low setting. But the beauty is you can set it up either way.
- While the manual discusses the applicability of the HI/MID/LO settings being for different room types (“live”, “dead”), keep in mind that you can also use these settings as somewhat of a reverse boundary compensation setting. For example, if you need to place the speakers near a wall, odds are you’ll find the “HI” setting works better than “LO”.
- I still feel like even in Lo that the midrange around 800Hz is a bit much. In evaluating the data I see there is some minor resonance that shows up in the impedance at about 900Hz and I wonder if that is what I was hearing.
- As for grill on versus off, I found grill on helps attenuate the highs and provides a more balanced sound in any configuration.
- At higher volume there is a standout between 2-4 kHz. The frequency response doesn’t show anything that is concrete for this. At best, there does seem to be a mild flattening of the response in this region before falling off above this region. However, I also see the harmonic distortion data indicates a rise around 2kHz. Truthfully, I’d be surprised if that was what I was hearing. But there is no way for me to say that it wasn’t. Or maybe I just didn’t hear what I think I heard… can’t rule that out. Subjective evaluations are tricky things.
- The bass isn’t as punchy as I’d prefer. This might be perfect for some (depending on room size or tastes) but I’d like a bit more (3dB) to get more kick drum bump at 50Hz. Either that, or use EQ to bring up 100-120Hz. When looking at the data I do see that there is some baffle step loss below 200Hz and my assumption is what I heard was the lack of midbass relative to midrange.
- It is worth noting though that my room is reasonably “dead” and I still prefer LO mode.
- On-axis doesn’t work well for me. I prefer slightly angled out. 10-20 degrees seemed to sound best to me.
- Width is really good and there seems to be good depth of soundstage on these. Interesting thing is that with panned sounds they sound deeper at the edges. I’d be pressed to say why this is but I do see that the data shows the horizontal radiation is wider between 1.5kHz to 5kHz. Maybe the panned sounds are in this region?
- Imaging is not precise as you would get with a narrower radiation pattern, but I can live with that.
I initially did not like these speakers. The manual indicated that the HI setting would work best for me since I have a pretty “dead” room. In application, though, the HI setting was too midrange heavy. After playing around with the different settings and aiming I found that the LO setting was best for my situation. I believe the reason for this is because my speakers are placed pretty far away from the walls (3 feet from the sidewalls and the front wall). Looking at the response data, the baffle step creates an imbalance between midbass and midrange (around 200-400Hz) in all (3) settings but the HI setting is the worst offender. When LO/MID are used the baffle step is made less noticeable so that when pulled further out in the room - and thus having less bass reinforcement from the walls - the bass is more in line with the midrange. The LO/MID/HI adjustability might make this the safest option for a passive speaker
in this style to go with, even though I personally still prefer the Wharfedale Linton myself.
