Thanks for doing this review Amir, I'd almost completely forgotten one of your members was sending it over to you. I'm glad it measured as well for you here as it did when I was putting it all together. As this is a technical forum, I've got some extra measurements here that members might be interested in looking at? I'll post some less technical things in the teardown thread you also started.
When I was getting tests done for european CE marking 3 or 4 years or so ago now I had to get independent measurements for the conducted and radiated emissions. I posted the graphs at the bottom here. What is interesting about these measurements from an end user perspective is that they pass at all. It is testament to the engineering work of Hypex in these modules (and of course me not throwing all their good work away by spraying emissions everywhere with bad implementation
) Hypex specifically state that they won't support integrators using these modules in a multi channel environment. This is mainly because switching amps powered with switching supplies are pretty bad at high frequency radiated and conducted crap. I was one of the first to start to develop a multi channel amps with the modules and Hypex engineers thought I was crazy
. The amp that went off for test was a 6 channel one based around 3 x NC502MP modules a 3 kW potential. The test graphs below are run at full power over the test duration. The conducted graph runs from 150kHz to 30mHz and passes, it is tight but it passed. The radiated runs from 30mHz to 1gHz, again it is tight but it passes. Now the interesting thing about this is that the test agency had never tested even a stereo class D amp above 500W let alone 3 x that passed at all, they were flabbergasted that Hypex had managed to produce modules that were this good. Most high powered class D amps have to be sold as professional amps not intended for domestic environments because they can't pass these tests. Some manage to just squeeze through but generally need some remedial work to do so. So hats off to Hypex here.
Stefan
PS, i s it OK to put a cheeky link to the amp page ? I'll delete if not.
https://kjfaudio.com/product/ma-01-flexible-amplifier/
