I’ve mentioned before I’ve had a number of experiences (along with the technical arguments) that made me sceptical of high priced cables from early on.
But one of the more recent experiences that reinforced my scepticism occurred just a couple years ago when I bought my benchmark LA4 preamp I needed some XLR cables between my phono stage and also my Benchmark DAC to the preamp.
An audio pal lent me a couple pairs of very expensive ($6,000/pair IIRC) thick jewellery looking XLR interconnects, which had been highly praised in places like TAS.
I didn’t require anything so extravagant but this is what he had available.
I used those for a long time until he needed them back. Then it was time for me to pony up money to replace them. So I replaced them with cheap
Audioblast cables from Amazon.
When I first put those audio blast cables in, just like even Amir experiences, there was a few moments where I was feeling like “ does something seem a bit different? I’m not sure if this sounds exactly the same or quite as good.”
The whole “ your mind will hear a difference when you are comparing A and B” thing.
But try as I might in listening closely, I couldn’t really detect anything I could put my finger on as different. All the same Sonic information seemed to be there.
Because of course it was.
And that momentary effect of “difference” pretty quickly faded away, and it became obvious that as electrical theory predicts the sound was just as good just the same as with the expensive interconnects.
And in practical terms using the Audioblast cables was an absolute relief - so much less bulky, more flexible and easy to manipulate then those big heavy stiff “high end” cables.
