khadas tone pro2 vs topping ex5
SOUNDMASTER
I want to connect hd650 and connect xlr active speaker to use.
Aside from the price, which one do you think is better in terms of performance and sound quality?
The two dac are fairly similar dacs.
Seems like a good enough comparison.
Get the EX5, the Tone2 Pro can run high-impedance stuff but with limited headroom, the EX5 has more power and you’ll probably prefer its ease of use to the Tone2 Pro’s arcane user interface.
Tone2 Pro는 고임피던스 기능을 실행할 수 있지만 제한된 헤드룸으로 EX5가 더 강력하고 사용 편의성을 선호할 것입니다. Tone2 Pro의 신비한 사용자 인터페이스.[/인용]
ex5가 더 나은 기능과 성능을 가지고 있습니까?
If my Google Translation of your post is correct, the sound quality is roughly the same between the two. The EX5 is easier to use, its headphone output has more power, and has TOSLINK and Bluetooth inputs, and remote control which is suitable for desktop and entertainment center usage. However, the Tone2 Pro is $150 cheaper, is transportable, and the sound quality is imperceptible between it and the EX5.
