The Tone Board was available for One Day Shipping via Amazon in my area for $99, I had some $$s on Amazon gift card and after just reading every page of that other 'wild' review thread I thought to surely order.
Khadas (Generic Version)
Schiit SYS
Akitika
A few notes for anyone interested:
Application Configuration
Using an old MacBook and Audirvana 2.9 I faced zero issues:
Next Tidal using Mac Desktop Application, again zero issues:
Hardware Considerations - Pre Amp may be required
It has been mentioned and noted that you can use the Tone Board as a standalone direct to a power amp with no pre amp needed but I do not feel there is enough to drive the volume to desired levels.
On the Khadas support site they note a process to update your firmware if you do not see Volume Control, this step was not necessary for me, I can see Volume Control with the Tone Board and expectedly I cannot see the same with my Music Fidelity V90.
So while digital volume control is available on the Khadas I feel adding something like the Schiit SYS makes a huge difference.
You can then adjust the SYS such that the MAX Volume on the DAC is where your max volume is more or less and from there, you can then adjust via your software control.
HiRes Audio
I own a few albums from HD Tracks, I've abandoned the idea in lieu of Tidal & Deezer, non the less my 24/96 files play with zero issues, interestingly Audirvana reports the files at 24/96 and shows them playing on the DAC at 32/96.
Listening
Sounds fantastic!
Any nuance I perceive between the Tone Board and the Music Fidelity V90 would be just my personal idea/opinion.
To be sure the Tone Board is 1/3 the cost of the V90 and the Tone Board is worth every bit of its price and certainly worth every bit of its savings as well.
Cheers to All!
Schiit SYS
Akitika
HiRes Audio
Listening
Sounds fantastic!
Cheers to All!
