3ll3d00d
- Joined
- Aug 31, 2019
- Messages
- 505
- Likes
- 366
you wouldn't expect a room issue to have a non linear response to volume changesissues below 100Hz may be because the microphone position picks up nulls,
I am guessing something is wrong with your SPL meter. I doubt your woofers would start port chuffing at these levels. I measure not 76 but 75dB steady state almost daily and it's not really too loud, 86dB is loud but not ear plug loud. I can't comment on 96dB, too loud is too loud from some level onwards.That is a very good point. Also, the subwoofers are located about 1.5m further away from the speakers. So to make "86dB" at the mic, they probably have to make closer to 90dB.
I am very skeptical that the tube amp is distorting at all. The horn has a quoted sensitivity of 98dB/W/m, and the tube amp puts out a nominal 110W. The amp would be barely chugging along at that volume.
BTW, I was surprised by how loud 76dB was. 86dB was intolerable, and 96dB had me plugging my ears. I normally listen at about 60-70dB. It is really quiet where I live. I find that when the noise floor is so low, music does not need to be turned up so loud. For example, I typically listen louder in the day and softer at night. I wonder if you guys have the same experience.
When you are talking about 76dB or 86dB, are you using dBA, dBC, or dBZ? If you are using a typical meter with dBA, you are really talking about ~1kHz to ~8kHz.I have compared my SPL meter to another SPL meter. It reads the sameSadly I think the SPL I am measuring is accurate. If anything, it is likely that the speakers are producing less than the SPL meter indicates because of room gain.
I calibrated my setup at 78dB using Bob Katz' approach. On well recorded music, this sounds to me like a sweet spot between too quiet and too loud. Going up 10dB sounds very loud on compressed rock, and acceptable for quieter classical recordings. So I can understand why this sounds loud to you.BTW, I was surprised by how loud 76dB was. 86dB was intolerable, and 96dB had me plugging my ears. I normally listen at about 60-70dB. It is really quiet where I live. I find that when the noise floor is so low, music does not need to be turned up so loud. For example, I typically listen louder in the day and softer at night. I wonder if you guys have the same experience
I think you better use white noise, it has peak to average ratio of around 6dB (this means the peaks have 4 times more power than average)I calibrated my setup at 78dB using Bob Katz' approach. On well recorded music, this sounds to me like a sweet spot between too quiet and too loud. Going up 10dB sounds very loud on compressed rock, and acceptable for quieter classical recordings. So I can understand why this sounds loud to you.
So SPL 76dB registered with what signal ? white noise?2. Output increased until SPL meter registered 76dB at mic position.
3. White noise played for 2 min.
4. Sweep done at 76dB.
How did you verify your sweep was at 76?
You can do this by playing a 1000Hz with the same level setting as the sweep...
band limited pink noise (500-2000Hz) is commonly used for this purpose so probably it's rather louder than you think then (another reason to use rew ....). A sweep with v coarse (eg octave) smoothing can also be useful.SPL of 76dB registered with white noise.
if you search Bob Katz' K-System, you will find his AES paper. Gearspace has a good article as well.What is Bob Katz's approach? Can I have a link please?
This definitely not the case!What is Bob Katz's approach? Can I have a link please?
1. SPL of 76dB registered with white noise.
2. I did not verify that my sweep was at 76dB. I ... umm ... sort of assumed that it would be![]()
Or better: use a calibrated mic like the minidsp UMIKThis definitely not the case!
Please do the 1000Hz sine wave test and set the level of the generator and the sweep the same
I was genuinely displeased to see this. What I see:
- Subwoofer: behaves extremely poorly. As volume gets louder, severe dynamic compression occurs.
- Woofer: behaves as expected at 86dB. By 96dB it is showing slight dynamic compression. I am unsure of the cause of the dip at 210Hz, could be some kind of cabinet resonance causing cancellation?
- Horn: exhibits the opposite of compression. In fact it exaggerates loudness. This might be why the horn sounds so lively.
- tweeter: behaves extremely poorly. Dynamic compression sets in at 86dB, but it "only" loses up to 2.3dB in loudness. By 96dB it is all over the place, that huge peak >15kHz is probably
It's certainly true that you can introduce new sources of distortion but that's a different situation, I was talking about modal response of the room.I can't agree that rooms remain linear with SPL increase. Ime, rooms go very unilinear with major SPL increase....particularly from subs.
Gotcha, thx.It's certainly true that you can introduce new sources of distortion but that's a different situation, I was talking about modal response of the room.
I guess it depends how loud you go and how the room is constructed, certainly I've gone v loud in my room (until the door frame groans) without seeing any such effects but my room is solid brick walls so probably they are not going to flex so much.
