Keith_W
- Thread Starter
- #221
Anyway, it is the weekend and I can play with my DSP again. I decided to redo everything from the ground up, because why not. I redid the time alignment via sine wave convolution method again, and was getting very strange results comparing left sub and right sub. So I compared them to each other:
Red = Left sub convolved with 50Hz sinewave tone
Green = Right sub convolved with 50Hz sinewave tone
It looks as if the subs are out of phase with each other. However, the initial deflection of both subwoofers is in the same direction. I was a bit baffled by this point. So I decided to take a mono recording (i.e. left + right playing together) to look for comb filtering.
Red/Green = uncorrected left and right sub + speaker response.
Brown = mono recording of left/right sub + speaker
Blue = mono recording of left/right sub + speaker, but with polarity inverted in the right sub.
As you can see, there is comb filtering in the uncorrected response. This disappears when the polarity of the right sub is inverted.
At this point I realized that the entire correction process was made with the polarity of one sub inverted. This is easy to do if you simply let Acourate handle both L/R without turning on your brain, those macros do it automatically and don't complain. So what does the mono recording of the corrected curve (with subwoofer polarity inadvertently reversed) look like? It looks like this:
Acourate seems to do a remarkable job of coping with the inverted polarity of one sub relative to the other. I must have inadvertently inverted the polarity of the subwoofer after moving the system. This is easy to do - there are two unlabelled Speakon connectors on my DIY subs, and if you connect them the wrong way, it will invert the polarity.
Anyway, the point of this post is: we rarely do mono recordings in our verification measurements. The lesson for me is to do them more often, because you can find things like inadvertent polarity inversion in one pair of drivers!
