If I am not mistaken, the founder of B&M has still an operating company called Silbersand employing the very sensor technology they invented in the 1970s. B&M still uses a similar principle as well at least for subwoofers and bass drivers, and so do other manufacturers.
Interestingly Müller´s solution of an electrodynamic velocity sensor seemingly circumvents most of the problems KEF has claimed to solve in a pretty complicated manner. His sensor coil is not following the shape of the voicecoil former (which would pose induction problems), but uses two separated windings on a little plate, placed in the middle of the voicecoil kind of crossing this area:
Sensor control service
Yes, I would not overestimate the advantages such a sensor and negative feedback loop can bring, but I would say they can be significant in a limited frequency band under certain conditions.
It might be interesting how that would affect the concept of active speakers as the general opinion expressed by developers using sensor technology already is that it does not make sense with bass reflex concepts, drivers with limited excursion capabilities and DSP crossovers with significant latency. Sounds to me as if a radically different active concept has to be designed around this little sensor.
Which is not really a problem to implement in a negative feedback loop if you know how these parameters are depending on each other.
