Vladimir Filevski
- Joined
- Mar 22, 2020
- Messages
- 563
- Likes
- 739
My bad explanation, I mean this:that's not true. if you have 2 slices only, you cant recreate the whole 3d response from it
Klippel system measures whole 3D space around the loudspeaker and reconstructs both horizontal and vertical frequency response graphs. Directivity Baloon from post #58 (and #1, of course) is the result of both reconstructed "horizontal and vertical" single frequency response graphs at any point in 3D space. As far as I know, the Klippel system can extract and present detailed frequency response (20 Hz - 20 kHz) at any point in the 3D space. But in the case of a center loudspeaker, it is not necessary - ordinary horizontal and vertical "on-axis" frequency response graphs are all you need. All center loudspeakers have good vertical dispersion, and given the small vertical height difference between tweeter and listener's ear (loudspeaker below the TV), the vertical listening angle is most certainly less than 15 degrees - and that frequency response is not much different than on-axis. So, for seating position of the listener anywhere in the room, knowing horizontal frequency response graph is all you need, eventually plus some small correction at the highest frequencies from the vertical response graph (there may be some additional differences around the crossover frequency).
