KEF Reference 2 meta Measurements and Review.
I might want to upgrade with the Ref 2 Meta center and four R8 Meta Atmos speakers. Is a 20% discount realistic? Only offers only show MSRP for me ...
Hello, long time no see!
I'm back with a center speaker from the KEF's Reference Series.
I took pictures when I was measuring it, but the pictures provided by the manufacturer are cleaner, so I'm posting it here.
Impedance
Along with a smooth phase response, the linearity is not significantly distorted even at higher power (2.83 V).
Frequency Response
It has a largely flat FR characteristic, with a bass extension at about 49.3 Hz (-6 dB).
The bass roll-off falls on a gentle slope of about -14 dB/oct.
Thanks to the gentle slope, we can expect a beneficial room gain.
Nearfield Measurements
Directivity
View attachment 299383View attachment 299384
As is typical of KEF, it has fantastic directivity controls.
The horizontally placed units make it difficult to achieve uniform horizontal orientation, but KEF has managed to overcome this.
The asymmetry in vertical directivity in the highs after 10kHz is probably due to...
....the orientation of this lemon squeezer.
Beamwidth
An even, smooth, controlled beamweed gives us peace of mind.
Thank you, KEF! :)
Polar plot
Due to the chunky mass of these speakers and the horizontally placed units, you can see that most of the sound is only radiating forward.
The polar plot of this speaker's vertical plane is closest to what I personally expect an ideal speaker to look like.
I love it.
Total Harmonic Distortion
Superclean.
The amount of distortion was so small that we had to increase the y-axis scale.
Equivalent Harmonic Input Distortion at 85dB SPL@1m
EHID may be new to some of you.
It corrects for the linear distortion of the measurement system (speaker-room-microphone) and provides THD related data as a result.
This allows you to measure THD free from the effects of the room, and it is very accurate.
However, due to the limitations of the method, it has the following constraints
1.It cannot see below F0 of the loudspeaker frequency response.
2.Linear distortions in the speaker itself, such as split vibration of the diaphragm or front baffle response, are also ignored, so it cannot be used for HF measurements.
Therefore, I only used 80 to 500 Hz for this measurement.
Anyway...
The performance is incredible!
Even at 80Hz, the THD is no more than 0.5%.
95dB SPL@1m
Even with the output cranked up to 95dB SPL, there's quite a bit of defense against distortion.
This guy still has plenty of room to spare.
Multitone test
It doesn't even achieve a maximum of -35dB.
It hits -45 to 50 dB in almost all areas.
Again, that's tremendous performance.
I remeasured using only measurement signals above 80 Hz.
(The speaker and microphone positions are fixed, and this is all automated).
Interestingly, despite being a closed speaker, the MD was reduced in the HF as well as the LF.
I don't know why.
Multitone test(with multiple output levels)
Again, SuperClean.
Even at 96dB SPL@1m, it's only -35dB.
That's phenomenal for a 6.5-inch loudspeaker with bandwidth down to about 50Hz in a closed construction.
Compression test
Center speakers are often used in movie or gaming setups.
As such, they need to be able to handle momentary peaks.
If you want to see the limits of this loudspeaker, you might want to ruin your ears before you do.
HF -2dB knob
On the back of this speaker was a knob to attenuate the HF by -2dB.
And I measured the impact of that.
My personal opinion.
Given its beautiful appearance, ample bandwidth and performance, and neatly controlled directivity, I think this is one of the best center speakers out there.
I am thinking of getting three of them for LCR!
Now I just have to find a good deal!
Looking at KEF’s website, it’s 2.5dB greater peak output, 2 dB greater sensitivity, another 100W of power handling and an F3 of 58Hz rather than 80Hz. Given the performance on display in this thread, I can’t see the Reference 4 Meta being necessary unless your listening distance is over 4m.
Yep! The Reference 4 Meta is a beast and the best center channel I have ever heard!!
