KEF R6 Meta, a great near field Monitor? Basic Measurements, Review, and Listening
Rmjesty
Hello everyone!
I recently started planning a new personal Dolby Atmos mixing studio, so I purchased the KEF R6 Meta to use as my new main monitor. Out of curiosity, I took some basic measurements in my current studio after it arrived to see whether it met my performance expectations.
Measurement equipment:
  • Speaker: KEF R6 Meta
  • Amplifier: Topping Mini300
  • Audio interface: Topping E8x8 Pre
  • Measurement microphone: MicW M215
Before taking the measurements, I calibrated the microphone’s sensitivity using an AWA 6021A acoustic calibrator to ensure accurate SPL readings.
First, the on-axis frequency response and CEA-2034
I obtained these responses by splicing nearfield and far-field measurements. The bass below 200 Hz is affected by the room, but overall, the speaker’s midrange and treble response is quite neutral. There are some minor ripples and a slight tilt in the treble, but its excellent directivity makes these easy to address with EQ. Effective bass extension is around 70 Hz, which is entirely sufficient for a system with multiple subwoofers.
The CEA-2034 measurements show KEF’s consistently excellent constant-directivity design.
Horizontal directivity is extremely smooth.
Vertical directivity is somewhat affected by the WCW arrangement in the midrange, but overall it is still far better than that of the vast majority of loudspeakers, especially for nearfield use.
Harmonic distortion and Compression measurements:
86 dB and 96 dB, distortion in the midrange and midbass is astonishingly low. Distortion does rise below 80 Hz, but this is precisely the trade-off I consider reasonable: multiple subwoofers can handle the frequencies below 80 Hz, allowing extremely low distortion across the full frequency range.
At 102 dB, bass distortion increases further, reaching around 1% at 100 Hz. During the sweep, the sound remained clean from the midbass upwards—all I could hear was a clean sine wave. This is among the best performances I have encountered in any speaker I have used or measured.
The compression test, referenced to the 76 dB sweep, shows approximately 0.5–1 dB of compression in the low midrange and uppermost treble at 102 dB SPL at 1 m. Given the driver sizes and the speaker’s price, this is an excellent result.
Step response and excess group delay plots show KEF’s well-designed crossover and the very low group delay of the sealed-box design.
Listening impressions:
After Calibrate the room bass response, I played several familiar mixing reference tracks and some of my own mixes in mono. What stood out was the lack of bass—which I expected—and an exceptionally clean, transparent midrange with seemingly unrestricted dynamics. As expected, the treble sounded slightly darker and “warmer” than other monitors with a flat on-axis response.
I then applied EQ to flatten the listening-window response, and the improvement was immediate. The treble became precise and clear, making it hard to stop listening. Even with highly dynamic electronic music, the speaker remained remarkably composed, apart from its limited bass output.
KEF has once again won me over through modern science and engineering. This really is the ideal nearfield monitor I have been searching for, one that fits my needs.
Comments and discussion about this speaker, KEF, and immersive music are welcome.
Preamp: -3 dB
Filter 1: ON PK Fc 654.16 Hz Gain -0.46 dB Q 10.263
Filter 2: ON PK Fc 2002.66 Hz Gain -11.35 dB Q 2.510
Filter 3: ON PK Fc 2029.51 Hz Gain 12.00 dB Q 2.561
Filter 4: ON PK Fc 3762.09 Hz Gain 1.41 dB Q 5.584
Filter 5: ON PK Fc 6335.26 Hz Gain 12.00 dB Q 3.140
Filter 6: ON PK Fc 6402.14 Hz Gain -11.99 dB Q 4.147
Filter 7: ON PK Fc 12072.44 Hz Gain -3.96 dB Q 4.584
Filter 8: ON PK Fc 12234.26 Hz Gain 3.90 dB Q 3.224
Filter 9: ON PK Fc 18493.66 Hz Gain 2.45 dB Q 1.260
Applying EQ like this will improve the listening experience and produce much more neutral response.
I tried 3 Q6 as LCR last year and they were great. As you showed, KEF's great directivity also makes them some of the easiest speakers to apply PEQ
Yes, for users experienced in measuring speakers, as long as the directivity is well controlled and dynamic headroom is sufficient, tonal differences caused by the on-axis frequency response can be corrected with targeted EQ or adjusted to personal taste.
