Alright your speakers have a sensitivity rating of
[email protected]/1m with minimum impedance of 3.3 Ohm at 150Hz so not at a frequency you can easily hand over to a subwoofer unless you want to cross extremely high using stereo subs.
So you'd need at least a 2 ohm stable amp with decent headroom to get you to 75dBC SPL at your desired listening distance with peaks into 95dB (20dB headroom)
Assuming you're listening at 9ft, that will be roughly 60 Watts into 4 Ohm
My recommend is the Wiim Ultra if you don't use Apple Music paired with a stereo power amp that can do 100Watts into 4 Ohm, no sweat and is stable to 2 Ohms. Get this combo set from Audiophonics -
https://www.audiophonics.fr/en/prod...nics-wire-rca-30cm-trigger-cable-p-19806.html
And invest in a subwoofer. This would do -
Arendal 1961 1S
