Oh, thanks so much! Is this the non-meta R3?Maybe you know this already, but this are the best infos I know of about the R300 and its drivers.
Kef R300 playground - measurements of raw drivers
www.diy-hifi-forum.eu
@Matias beat me to it. ;-)
EDIT:
But to be a bit more useful I took my Umik and made some distortion measurements of the coax with crossover in the original cabinets.
R396dB/1m measured at 0.5m.
I checked my setup and somehow the calibration is off.
The voltage was 2.3Vrms, that is more like 86dBspl
R30096dB/1m measured at 0.5m
The R3 has a flatter FR and somewhat lower H3. H2 is a bit higher though.
The coax in the R300 is not bad at all.
I remember that I measured these speakers before but I could not find the file. IIRC the woofer in the R300 is one tier below the one in the R3, it has significantly (8-10dB) more distortion (similar to the one in the Concerto meta), but I am too lazy to measure again.
Attached the full measurement file with 86dB/1m measurements, too.
I really hate when this happens.I checked my setup and somehow the calibration is off.
Wow, what a thorough reply! Thanks so much!I really hate when this happens.
So I went at it again this time with the correct calibration. And I measured the woofers too.
What I said about the differences of the two different coaxes and the woofers still holds. But see for yourself.
Woofer measurements below 200Hz are contaminated with room influence and below 100Hz are useful only for a trend of distortion.
Coaxes are gate 6ms so this is quasi-anechoic.
Everything is measured from 50cm so the levels are 6dB higher than "normal".
If my guess is right that the "wobble" 2k-6k in the R300 response is due to baffle and edges, then the "shadow flare" seems to do a good job in the R3.
Cursor at 1.2kHz.
Distortion measurements.
View attachment 473762View attachment 473763View attachment 473764View attachment 473765View attachment 473766View attachment 473767View attachment 473768View attachment 473769
And the full measurements
The R300 were a very good used deal and are kind of in storage. I bought the R3 later when they were in a low price offerI'm just curious, why do you keep both R300 and R3? Two different systems?
Hi, i try to find how good are the q concerto meta compared to the r300 (which i had a few years ago). You say the distorsion is the same ? what are the biggest differences between those 2 speakers ?Maybe you know this already, but this are the best infos I know of about the R300 and its drivers.
EDIT:
