KEF R3 Speaker Review
Fedebelga
Any thoughts? Enough punch to drive the R3's?
Ata
Adelaide, Australia
More than enough punch. I am driving the less sensitive LS50M with a low/mid-range AVR with no complaints and to an SPL where THD shoots up signficantly.
Synergy4
Silicon Valley
It seems the Revel R3 score appears to be very high, but Amir did not seem too impressed after listening to the R3. Was it just too neutral?
"Alas, once again subjective feeling was low. My standard routine is to cycle through my reference clips that I have selected during all my normal listening to sound superb on my Revel Salon 2 Speakers. Sadly hardly any of them sounded all that good here. Yes, the highs were there. The lows at times were there. But overall experience was unexciting and unengaging for lack of a better word.
To make sure my mind has not gone crazy, I replaced the R3 with Revel M16 which I recently reviewed. Wow, all that gorgeous came right back! There are two things I clearly detect:
1. Warm, fantastic mid to upper bass. I can't emphasize enough how much difference this makes and how it impacts my subjective reviews.
2. There is a "loosness" to notes that is hard to describe but notes are separated and delightfully clean and pleasant. I get this same sense when I EQ a speaker for a room."
BrokenEnglishGuy
EDIT: later testing showed that the room mode at about 105 Hz was impacting the tonality of the speaker. Once I filtered that, the sound was very good. I have since made this part of the protocol.
sweetchaos
The Curator
BC, Canada
The UPDATE is written below it. Don’t know how you missed it.
Synergy4
Silicon Valley
That to me, does not seem like the music then sounded exciting and engaging. It rather leaves the impression of just OK sound.
BrokenEnglishGuy
He just didn't fix the room before listening the speaker, the R3 was one of the first reviews.
dshreter
If one prefers wider directivity, or is most used to the sound of it, the R3 is going to sound less enveloping.
Amir’s review, with or without the update, isn’t really surprising since he lives with Salon 2s. If it were the other way around and he lived with R3s instead he might think the Salon 2s cacophonous with fuzzy imaging. We can never know though.
Synergy4
Silicon Valley
In the end, comparing speaker reviews is a very fuzzy experience. It is a bit like peeling an onion when you get done, there is nothing left but peelings.
Looking at options, it is not clear what the best choice is: Revel M106/105, Kef R3, BMF Monitor, Revel F208
Maybe the Kef R3 will be good enough for now?
This is difficult, because I listen to a very wide range of music types; Classical, Jazz, Blues, Piano, Classic Album Rock, Folk, Electronic & New Age. It is really nice when one can hear all the instruments and the voices cleanly & clearly, but sometimes a good pipe organ can be fun.
My Velodyne F-1800R servo 18" driver sub woofer can handle the very low end of the audio spectrum.
sweetchaos
The Curator
BC, Canada
Completely different price points, and design criteria.
Revel M106. Under $2200/pair
Revel M105. Under $1650/pair
Kef R3. Under US$1700/pair
Philharmonic BMR. Under US$1700/pair
Revel F208. Under US$5500/pair (how did the budget just double?)
One of these doesn't below with the rest.
Also, like with wine, there's different flavours of speakers. ;)
Synergy4
Silicon Valley
Well sometimes one needs to consider, if the budget is just too low, for the expected results.
A nice velvet Cabernet or Chateauneuf du pape is nice, but sometimes a petite verdot, petite sirah, malbec or old vine zinfandel will do.
sweetchaos
The Curator
BC, Canada
From my guide:
Here's bookshelves:
Under US$2200/pair:
RecommendationPSLFX
#1Kef R3 (Amir) (Erin)6.535
#2Polk R200*6.342
#3Elac Debut Reference DBR-62 (Amir)5.843
WorthyRevel M105 (Amir)5.851
WorthyRevel M106 (Amir)5.846
WorthyRevel M16 (Amir)5.645
WorthyJBL HDI-1600 (Amir)5.838
WorthyKef LS50 Meta (Amir)5.743
WorthyPhilharmonic BMR (Erin)5.146
Here's towers:
Under US$5500/pair:
RecommendationPSLFX
#1Revel F208 (Amir)6.726
#2Revel F206*6.436
#3Infinity R263*6.032
WorthyRevel F226Be (Erin)6.043
WorthyRevel F35 (Amir)5.739
WorthyJBL 4309 (Amir)3.841
WorthyKef R5 (Erin)5.933
WorthyKef R7**
WorthyKef R11***
** No spinorama for Kef R7. I'm including it because we have Kef R3, R5 spinorama already, so it's not a stretch to imagine these are better.
** No spinorama for Kef R11. I'm including it because we have Kef R3, R5 spinorama already, so it's not a stretch to imagine these are better.
where:
* = no precise spinorama is available, only quasi-anechoic spinorama available with less resolution
PS = preference score
LFX = low frequency extension = measured at -6db point
As you can see, there's plenty of options for each budget. ;)
You have to decide what's important to you:
- Deepest bass you can afford? look at best LFX score (from my table above)
- Most theoretically preferred (aka best preference score)? Look at top "FS" score (from my table above)
- Best vertical directivity? Kef R series.
- Best wide dispersion speakers? Philharmonic BMR, and a few Revels
- Looks? Towers vs bookshelves. You decide.
- Best aesthetics/finish? That's subjective. You decide
- Power handling? Towers. Bookshelves are always weaker.
- Distortion handling? Look at each review, and look at 96db distortion plots, and compare to other speakers. Towers will mostly outperform bookshelves.
Luckily, we're not limited by GREAT OPTIONS, only by our imagination. :D
thewas
Also he does the listening tests of his loudspeaker NFS reviews with a single speaker and we know from Toole's research that the less loudspeakers are used the more wide directivity is preferred.
Kachda
NY
From my guide:
Here's bookshelves:
Under US$2200/pair:
RecommendationPSLFX
#2Polk R200*6.342
Here's towers:
Under US$5500/pair:
RecommendationPSLFX
#2Revel F206*6.436
WorthyKef R7**
WorthyKef R11***
where:
I have heard both the R3 and the BMR and I definitely found the BMR to go lower than the KEF.
BrokenEnglishGuy
The R series goes deep, the thing is their slope its kind of a weak. ( room friendly? too much friendly? xD )
But you can modify the slope 60hz-100 hz - > 20 hz (port tunning), using a low-shelf filter adding 1 or 2dB, 3db. And ButterWorth filter for cutting at the port tunning
R3: 40hz
R7: 31hz+40hz.
BIGB
Hi All,
Wanted to check if Yamaha RN 803 is capable of driving Kef R3(just ordered) I’ve a REL T9i with high level connection to 803. Should I upgrade the amp? Room size is 14x11 feet. I listen at moderate volume only. Thanks
hch
Hi All,
You should be fine with the 803, I have driven mine with 2x45w and that works great at moderate levels. With the room size you have and the sub, I don't think you'll ever need more than the 803 in terms of power.
hch
BTW I see that the Yamaha RN 803 produces 194 watts into 4 ohms and has a SINAD of 92, so this is a good amp. Nice performance at a reasonable price this.
