KEF R3 meta Measurements
Steve Dallas
A Whole Other Country
I have enjoyed literally every wide dispersion experience i have had more than narrow dispersion.
Data point of one. Of course, this is not always the case:
abdo123
Brussels, Belgium
Well you asked in what world and i have answered that in mine it does :)
Steve Dallas
Fair enough. Bizarro World has a population of at least one!
Vacceo
In what bizarro world is wider dispersion always superior?
To my ears, smooth directivity trumps wide dispersion, and narrower dispersion often works better in small rooms, reflective rooms, etc.
I also prefeer narrow dispersion. It is easier to tune a multichannel system when the interaction of a lot of speakers with the room is a bit lighter.
dogmamann
Why would you assume someone has only used KEFs? If that is directed at me, you are hugely mistaken.
There is such a thing as a soundstage that is too wide. Lighting up the side walls in a small room creates reflections that smear that wide soundstage to the point many people would choose narrower dispersion.
And you did not answer the question. Why does a speaker having a single better trait automatically make it superior as a matter of fact?
Even if there is one category for which the much cheaper r series doing better than the references its a huge win, considering their price gap. In this case they are quite similar (old reference and new r metas) and metas has lower tweeter resonance due to the meta material (that’s what Kef claims, though I dont see it in measurements!!) also directivity is wider. The old references while tonally was an ok speaker, lacked soundstage width of many speakers under 1000 dollars.
exm
Can I ask you how would you know? Have you demoed them? Owned them? I have owned the Reference Fours (1990s), R900s, R11s and now Reference 5s (non-meta) as well as Model 100c, 200c, 204/2c, R2c, Reference 2c and now Reference 4c. For sides I have owned Reference Twos (1990s), R3s and now R3 Metas. So I can say with some authority that I have experience with Kef speaker. To say the lack soundstage width is utter (I want to use another "b" word, but I'll use): baloney.
geox
I'd like to hear comparisons with Polk R200 - which is nearly 1/3rd the price (here in Australia)
dogmamann
You don’t need to demo them, you look at the graphs and you know the whole story
Alexx
I read that the new Meta series has a different crossover and also the components (especially capacitors) are of better quality than the previous series.
@geox: I listened to R 3 (not meta) with Polk R200, for my taste better Kef, it remained less tiring and more "warm" in the medium-high range.
Polk R200 too detailed and forward in the high range (the tweeter too present) reminded me of the Dali Opticn 6 MKII.
I repeat they are personal sensations but polk after a while listening tired due to the too present tweeter.
See you soon.
dogmamann
See you soon.
Crossover parts should work, there is no audible difference between capacitor brands and cables. Kefs r series crossover is in the image attached. Looks well made imo to the specs they are needed. Exotic parts is needed for marketing, beyond which they don’t do anything.
jackocleebrown
Just going to leave this here:
thewas
But there exist no comparable measurements from the R Meta and other KEF loudspeakers from the same source yet?
thewas
jackocleebrown
Hi
What does mean the green line? The red line in the first image can mean poor componentens and the blue the components from the r meta, but the green line?
Ty
These graphs are from the Reference white paper in 2014, they're not specific to the R-series or R-series META. But it's plainly false to say that "there is no audible difference between capacitor brands".
jackocleebrown
Very interesting and surprisingly high differences, could it be that the ones with the high distortion were electrolytic capacitors and/or iron core inductors?
It's a while ago so I can't remember exactly which components are in the graphs. But yes, electrolytic capacitors have easily measurable distortion and the distortion level varies from manufacturer to manufacturer for components with exactly the same spec. in Fig 54 the red and greed are most certainly two different types of electrolytic cap. I suspect the blue is a PP cap (PP caps all have very low distortion indeed). Cored inductors also have easily measurable distortion but there's big variation for components with the same specification depending on the core type, geometry and material.
jackocleebrown
Did you mean there are audible differences outside the measured parameters mostly discussed here ?
I mean exactly what I wrote: it's plainly false to say that "there is no audible difference between capacitor brands" and I backed this up with objective data showing clear THD differences.
