Thus far, I have found the recommendations on this forum to be right on the money. Alas, not so with this one, especially when contrasted with Amir's review of the ELAC DBR 6-2. To my ears, it was quite the opposite. I found the ELAC DBR-62 to be absolutely devoid of detail, and its soundstage indistinct. My only impulse is to switch everything off and go for a walk. To be honest, I have never found a set of speakers to be so dull, so boring. The KEF, on the other hand, are the very epitome of musicality, detail, balance, and a soundstage that leaves me gobsmacked at times, given the price point.
What gives? Psychoacoustics? Who knows? I ran a blind comparison test with two people, one from within my family and one from without, and there was not even a shadow of doubt -- the KEF won in a heartbeat across a range of music genres, all played using the same system with hi-res Tidal streams. Admittedly, there was some lag whilst I switched cables, but again, I did this randomly, not in any predictable way, as I went across genres. Not in a single instance was there a contest. I should add that both were "broken-in" on the same system, and for the same time -- about 50 hours. So, I did the best to conduct as good a subjective comparison as I could.
Conclusion: While the measurements and Amir's subjective impressions might well be true, one's ears are the way to go when choosing loudspeakers. I will not say this for anything else -- DACs or AMPS or Streamers, as in those instances, objective measurements often don't lie. However, with speakers, one can not escape the ambience -- the listening room, the way it has been set up and treated, and so forth.
