KEF q300s powered by NAD C320BEE @ 50 watts per chan, am I underamping these things?
Rollingsound514
Montreal, Canada
In the forums opinion should I be aiming for more power than 50 rms per channel on these things? I want an amp that could one day power some ls50s when I can afford them, but q300s are what it would be powering for a while. The NAD sounds decent but it doesn't blow me away really... Thanks for your opinions
RayDunzl
Central Scrutinizer
Riverview FL
Specs:
MAXIMUM OUTPUT 106dB
AMPLIFIER REQUIREMENTS 25 - 100 W
SENSITIVITY 85dB (2.83V/1m)
NOMINAL IMPEDANCE 8 Ohms (min.3.2 Ohms)
Opinion:
If I had a pair, I'd surely attach one of my dusty old 250W amps.
bigx5murf
Depends on your room size and how far you're sitting from them. 50wpc is probably overkill if you're using near field.
