Hello and
welcome to ASR.
Let's check a few things here
The Audio Technica AT-LP60X has a switchable phono pre-amplifier for phono or line-level output.
Which have you selected?
Further though, what inputs have you plugged the RCA output into?
Your amp has 2 x AUX & 2 x Phono inputs.
If you have the turntable set to phono output, you will need to plug the RCA's into one of the phono inputs.
If you have the turntable set to line output, you will need to plug the RCA's into one of the AUX inputs.
Do you maybe have the turntable set to phono output, but have it plugged into the AUX? If so, you won't get much sound...
When the turntable is set to line output, it uses the built-in phono preamp to boost the signal to line-level.
When set to phono output, it does not use the preamp and the signal remains at "phono-level".
JSmith
