Considering this is KEF’s cheapest speaker this is quite good!
i wouldnt buy a kef coax, shit overcomplicated woofers with no throw at all.
Speaker throw ...
Wouldn’t a sine sweep do the same and be more repeatable?If it is what I think I am hearing, it is exactly the resonance issue I heard with Elac speaker that created a lot of fireworks. You need a clip like this that is borderline having that resonance. Then the speaker hits on the precise note and it gets amplified. Your track sounds very similar to the one and only track I have that brings this to surface.
They have coax models also with separate woofers…i wouldnt buy a kef coax, shit overcomplicated woofers with no throw at all.
I'm familiar with that song. That is definitely a speaker resonance, not inherent to the source. None of my speakers have such a strong resonance playing that part.
Not sure if it's a flaw with that particular Q150 or if it's the resonances around the 1khz mark being triggered. Oftentimes with cheaper speakers that have multiple significant(enough to show up in measurements) resonances, even if they're not too bad on a sweep, if you get the exact right frequency it's very noticeable.
That happened to Amir on the Elac UB52.
A normal sweep runs too fast to hear it. I had to run a narrow range sweep to hear it that way which requires knowing its frequency. My measurements showed it but Erin's don't which makes this harder.Wouldn’t a sine sweep do the same and be more repeatable?
Can’t you adjust the sweep speed with modern testing systems? I used to use Clio or MLSSA with a close field microphone. Both systems were SOTA back in the 90s and both had sweep speed adjustments. A resonance that crates a crackling sound should be visible on the microphone output, irrespective of the FR anomalies. Then I manually altered the frequency using a Radio Shack oscillator to locate the frequency with confidence. The only problem with this method is the risk of frying the tweeter. Otherwise, for most mid and low range drivers there should be no problem.A normal sweep runs too fast to hear it. I had to run a narrow range sweep to hear it that way which requires knowing its frequency. My measurements showed it but Erin's don't which makes this harder.
OK. Then the next step is to frequency sweep the speakers to check for resonances and stuff.
Online Tone Generator - generate pure tones of any frequency
www.szynalski.com
Are you going to listen to a five minute sweep on every speaker you test?Can’t you adjust the sweep speed with modern testing systems? I used to use Clio or MLSSA with a close field microphone. Both systems were SOTA back in the 90s and both had sweep speed adjustments. A resonance that crates a crackling sound should be visible on the microphone output, irrespective of the FR anomalies. Then I manually altered the frequency using a Radio Shack oscillator to locate the frequency with confidence. The only problem with this method is the risk of frying the tweeter voice. Otherwise, for most mid and low range drivers there should be no problem.
PS. I did a similar test for locating cabinet resonances, where the microphone was swapped with a cartridge on a tone arm.
I’m sorry but you seem to have misunderstood me. I wasn’t suggesting for you to add this test to your tests. Your tests are good as it gets.Are you going to listen to a five minute sweep on every speaker you test?
I understood what you said. Was on the phone so couldn't type properly.I’m sorry but you seem to have misunderstood me. I wasn’t suggesting for you to add this test to your tests. Your tests are good as it gets.
My suggestion was purely a diagnostic method for pinpointing faults in faulty units. It was not meant to become part of a review’s tests. I was simply suggesting that a sine sweep is better suited for diagnosing faults than playing back music. I’m sorry if I was not clear.
From what I understand about resonances is that they need (relatively more) time to build up, so if the sweep is really short like what the Klippel uses I don’t think you can pick it up like that just from hearing the sweep.Wouldn’t a sine sweep do the same and be more repeatable?
Thank you for the explanation. Learned somethingI understood what you said. Was on the phone so couldn't type properly.
Expanding on what I said, it is good to have a standardized music track that catches this problem. That way if you miss it in measurements as it seems to be the case here, you will still catch it then. When I found it last, I noticed that it in a 2 or so second sweep it was not audible. I had to make something like a 10 second sweep covering a narrow range. The same sweep run across the full audible range would be minutes long as I mentioned so not practical as a replacement for the music track.
I didn't realise that Klippel sweeps were that short. 2S for ten octaves is a pretty fast sweep. I used to do 16S sweeps and limited the range to the centre eight octaves. (The range limitations was mainly to avoid the tweeter frying but also the top octaves had little energy capacity and the bottom octave issues are almost as visible as audible.) That allowed 2S per octave, an order of magnitude slower than Klippel. I slowed the sweep specifically to allow the driver time to get energised for each frequency. However, my test gear couldn't run much faster anyway. It seems sometimes old beats the new, old as in me and my equipmentFrom what I understand about resonances is that they need (relatively more) time to build up, so if the sweep is really short like what the Klippel uses I don’t think you can pick it up like that just from hearing the sweep.
