Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Lol, I just watched that video and he basically un-sold me on a set of the Q11 Meta towers(which I am assuming will use the same concentric tweeter/mid driver as the Q Concerto) because of his comments about their falling high frequency response and their use in a larger, more open room like my family room. But I really need Erin to review the Q11 Meta because perhaps they will perform differently in the high end than the Q Concerto.
All 3-way Q Meta models use the same Uni-Q and similar tuning (I have the Q7 Meta which I deliberately chose over the 11 which I wanted to buy initially), but that is nothing that a (P)EQ cannot fix if you like a bit hotter treble.
No worries, as I had written earlier in this thread due to its more continuous vertical directivity and since in my room and listening distance I don't need the extra 3 dB max SPL the Q11 would provide.
Also the Q7 Meta which I recently bought because of the data in that paper isn't much worse plus offers better vertical directivity and even significantly lower price:
Tonality: 6.83
Bass extension: 32Hz
Flatness: ±2.1dB
Their spins are extremely similar and the Q7 has a even a tad more bass between 35 and 70 Hz:
I've had the Q7 and Q6 center for a little while now, and really appreciate this thread and the info provided. Helped me solidify my decision to go with these speakers. Merry Christmas!
Edit: I went with the Q7 over the Q11 solely based on the depth difference between the two speakers to give them more space off the front wall and only sitting 11-12ft away.
Edit: I went with the Q7 over the Q11 solely based on the depth difference between the two speakers to give them more space off the front wall and only sitting 11-12ft away. View attachment 416465
Has anyone been able to compare the Q650c to the Q6 Meta?
The q650c in my listening space is definitely on the bright side, and when correcting full range in Dirac, other seating locations have mentioned that the sound is dull. If possible I would like to only EQ up to 500hz.
The Q6 Meta seems to have a much better measurement overall, but then, that begs the question, is this "better measurement" really worth the $600 investment vs. what Dirac can do to the Q650c?
