Rõlnnbacke
Well, the 2018 R with wadding damping.
Well, the 2018 R with wadding damping.View attachment 396894View attachment 396895 From the white paper. Also: "the dome vents through the centre pole of the magnet system to a cavity filled with absorbent wadding. The cavity is tapered to that, when the wadding is inserted, it becomes more dense towards the rear of the cavity, gradually increasing absorption.All the rearward energy is absorbed and cannot re-radiate through the dome after being reflected at the back of the cavity." So that would be (about as) good ass well.
The MAT is only used for the tweeter with every model.good remark : the mat seem in the center : more for the tweeter
on the concerto the bass speeker we strangely dont see it :
Would the Meta magic even work that well for a midrange? Has anyone tried?The MAT is only used for the tweeter with every model.![]()
Theoretically, metamaterials can be designed to damp any set of frequencies, as this style of layers started to be use for noise reduction in factories.Would the Meta magic even work that well for a midrange? Has anyone tried?
So.. actually fitting something big enough to matter at those midrange frequencies.... too large?Theoretically, metamaterials can be designed to damp any set of frequencies, as this style of layers started to be use for noise reduction in factories.
I think the one KEF uses is optimized for high frequencies.
they wait 11 gen to see tweeter no goodThe MAT is only used for the tweeter with every model.![]()
That would be a question for AOR or Dr. Oclee-Brown, who, after all, designed and adjusted the speakers; MAT included.So.. actually fitting something big enough to matter at those midrange frequencies.... too large?
I'm only considering above 400hz as the R version needs. And would it even be plausible to build yourself - worth it for that matter?
Have you seen the Nautilus with their long rear spikes? MAT is meant to provide the same functionality.they wait 11 gen to see tweeter no good![]()
The MAT for the tweeter appears to be an array of folded tubes (for want of a better description) of various length, the length tuning each tube to a specific frequency. The array together covers the working frequency range.So.. actually fitting something big enough to matter at those midrange frequencies.... too large?
the high its what you lose 1st when you become oldThat would be a question for AOR or Dr. Oclee-Brown, who, after all, designed and adjusted the speakers; MAT included.
Plausible to build yourself? Sure. It would have to be larger - either 2x or 4x the one in use in the R meta and Ref meta. (I can never remember the frequency/size relationship). The parts are nothing particularly special, being injection moulded. A hobbyist could certainly 3D print a functional MAT disc. In fact, we've printed functional MATs ourselves on some fairly common 3D printing hardware. The challenge is the design - we spent a long time working out how to best match up the disc with a normal tube that comes off the back of the tweeter. The result of that investigation is the subject of the patent we have in this area. The answer is a conical duct that tapers at a particular rate, with a relationship to the lowest frequency of MAT. This is fine in theory, but actually designing something that works for your situation gets tricky and pretty much necessitates the use of FEA. Not to underestimate the dedication of ASR users, but I would imagine that few people have access to those kinds of resources.So.. actually fitting something big enough to matter at those midrange frequencies.... too large?
Hypothetically, would it be possible to fill all the internal walls of a cabinet with metamaterials meant to make them innert in pretty much all frequencies. The practicallity of doing that is nowhere to be found, I´d imagine.Plausible to build yourself? Sure. It would have to be larger - either 2x or 4x the one in use in the R meta and Ref meta. (I can never remember the frequency/size relationship). The parts are nothing particularly special, being injection moulded. A hobbyist could certainly 3D print a functional MAT disc. In fact, we've printed functional MATs ourselves on some fairly common 3D printing hardware. The challenge is the design - we spent a long time working out how to best match up the disc with a normal tube that comes off the back of the tweeter. The result of that investigation is the subject of the patent we have in this area. The answer is a conical duct that tapers at a particular rate, with a relationship to the lowest frequency of MAT. This is fine in theory, but actually designing something that works for your situation gets tricky and pretty much necessitates the use of FEA. Not to underestimate the dedication of ASR users, but I would imagine that few people have access to those kinds of resources.
noHypothetically, would it be possible to fill all the internal walls of a cabinet with metamaterials meant to make them innert in pretty much all frequencies. The practicallity of doing that is nowhere to be found, I´d imagine.
Well, that's... not great...
its proof data and curve its not real lifeWell, that's... not great...
