Hi all just wanted to share my new kitchen setup.
Which is KEF LSX II and a ( shock and horror ) REL Tzero mkIII ( chosen on physical dimension and price )
The KEF are much better than my placement of them as this is in our kitchen and some consensus must be reached about placement.
In position you see them in the picture , moving them forward rigth to edge of our counter makes imaging much better , moving to the back is not good at all is the compromise the inbuilt eq makes it possible to adjust the tonality to my liking and thier very good acoustics combined makes it very suitable for what I do in the kitchen , of axis listening never in the sweet spot .
But playing around with them suggest that bying the “stick” stand from KEF and a free placement should also yield precise imaging.
The product is very well balanced it basically has everything a good hifi should have , but a bit physicaly limited in scale and dynamics.
I think this is the most effective way to get hifi at this price level very nifty design juggling the 1000’s of compromises inherent in speaker design and at arrive at this . If you change anything something else would be crappier and the totality would suffer imho.
And ofcourse this is my first modern speaker everything else I have is 15 years older.
And I wanted to experience KEF coax drivers and trying them from the low end tells a lot , I like them .
