Reliability/longevity is the biggest concern, IMO.Wow, the pref. score . my jaw dropped. Looks like this will be my dream speaker if I am to upgrade. Is there a reason NOT to buy these ?
Unfortunately, that can only be proven with time.
You won't get this kind of performance from a passive speaker.A no buy for me it's the integrated amp ,wish it was passive
No easy room correction and inability to create a multichannel. Those are the only reasons why I'm not upgrading to them.Wow, the pref. score . my jaw dropped. Looks like this will be my dream speaker if I am to upgrade. Is there a reason NOT to buy these ?
I would imagine this will be sitting in my living room for stereo music playing, so no multichannel needed - I don't even need a sub because they pref. score is even higher than many speakers with sub .No easy room correction and inability to create a multichannel. Those are the only reasons why I'm not upgrading to them.
The best of those cons is that they're not that hard to fix.
in theory it can. just quite a bit unnecessarily complicated/inelegant solution.Can someone explain why you can't use these in a multichannel setup? I know it has been discussed here millions of times, but i fail to understand the reason why. Can't they be used as a pair of dumb active speakers? What's the problem, do they show a latency that is not constant or something like that?
Thanks a lot
Thanks! I guess i am more confused now than beforein theory it can. just quite a bit unnecessary complicated/inelegant solution.
in theory you can feed those speaker with RCA from a preout of AVR. however there are few problems - bypassing the streaming capacity of these speakers, volume control is a bit finicky, and some people would prefer XLR instead.Thanks! I guess i am more confused now than before
I would go out listen to them , and maybe wait for the stereophile review. After one year we will also know if ls60 is reliable with the electronics. I think that they sound really good.Wow, the pref. score . my jaw dropped. Looks like this will be my dream speaker if I am to upgrade. Is there a reason NOT to buy these ?
you must be kidding right?and maybe wait for the stereophile review.
There's no problem whatsoever, people just get a bit weird about using smart speakers as dumb ones.Can someone explain why you can't use these in a multichannel setup? I know it has been discussed here millions of times, but i fail to understand the reason why. Can't they be used as a pair of dumb active speakers? What's the problem, do they show a latency that is not constant or something like that?
Thanks a lot
My theory, which can be completely wrong, goes as follows.Thanks! I guess i am more confused now than before
Honestly, anyone with that much cash kicking around, may as well use a Genelec 8361A as a centre. If we're going actives, may as well go all out. It should play well with the KEFs acoustically.Edit: Oh, and if you want to use one as a centre, that'd be fine, but you wouldn't be able to split a pair for that purpose and sell the odd one to someone else doing the same thing.
From the specs:LS60 Wireless II could fix those though. A sub-out would be a step into right direction
Output
Primary speaker
RCA Subwoofer output
Secondary speaker
I haven't listened to the LS60, but I have listened to the Blades. If the actives are relatively close, they are indeed amazing speakers.you must be kidding right?
No I am not buying them right now, not even in near future (2-3 years). but I found something that both looks great and sounds incredible (based on the pref. score). Added them to my wish list so I have something to look forward to and probably save money for
I have listened to the Blade but not the LS60. I'd definitely love a side by side blind test. I'm pretty sure that'd mistake both, but it would still be a fun test to take.For all of those whining about a passive version. There is one - it's called the blade ii meta Yes it's bigger (and much much more expensive) because it doesn't have the benefits of being active.
Quite significant for a current KEF pair deviation between 200 and 600 Hz, wonder if it is due to different boundary filter selection?Hifi News measure the LS60
KEF LS60 Wireless Loudspeaker Lab Report
Lab Report With its line/digital inputs and fully integrated Class AB and Class D amplifiers, KEF's LS60 Wireless has no meaningful 'sensitivity' that might be compared with a standard passive loudspeaker. Neither does it have any meaningful 'impedance' – the internal amplifiers are certainly...www.hifinews.com
