Oh wow, looks like a pretty large room!
The Focal Stella Utopias at the back are about 1.5m tall and look absolutely tiny.
If KEF takes the step to allow an external eq software, my guess is that I'd be Dirac too or Audyssey. Both are system-agnostic while other software like Lyngdorf or ARC are very tied to a manufacturer.Important info on the Dynaudio release:
Pricing (RRP)
Focus 10: €5,000 / £4,399 / USD $5,500
Focus 30: €7,500 / £6,499 / USD $8,250
Focus 50: €10,000 / £8,699 / USD $11,000
They also say:
There are three models: Focus 10 (a two-way stand-mount speaker), Focus 30 (a two-and-a-half-way floor-stander) and Focus 50 (a three-way floor-stander).
Here are some of the (many) highlights:
Class-leading versatility
Whether you’re starting from scratch after upgrading from a smaller system, or you’re building on your existing set-up, Focus fits in seamlessly.
Its built-in high-end streaming platform takes care of everything online, while coaxial and optical digital inputs and analogue connections mean a CD player and even a turntable can still sit front and centre alongside streaming services. There’s even a subwoofer output with trigger, Ethernet, and it’s Dirac Live-ready for power-user calibrators.
Want to go wireless with your TV? WiSA connectivity makes it a breeze. No cables needed.
Amazing user friendliness
Listen to what you want, how you want. Focus supports Spotify Connect, TIDAL Connect, Apple AirPlay 2, Google Chromecast, Qplay, UPnP, Netradio and Bluetooth. And it’s Roon Ready, too. If it’s streamable, Focus will play it.
It will auto-switch inputs depending on which source you want to use, it will turn on automatically when an input is connected, and it will even sense when the included magnetic Smart Grilles are applied – and adjust its EQ to compensate.
And if you don’t want to use your phone to control it after using the free Dynaudio set-up app, there’s a Bluetooth remote control included in the box.
Studio-grade performance
What goes in, comes out. Focus uses the same legendary Dynaudio driver technology (including the renowned Cerotar tweeter) and the same type of amplifiers the company uses in its professional studio reference monitors.
Then there’s the sealed-box design which, thanks to some sophisticated digital signal processing, delivers even tighter, deeper, more controlled bass performance. Users can also compensate independently for each speaker’s position in their room from within the app – meaning no sonic surprises when you’re setting them up. Wherever you’re setting them up.
The whole Focus family was measured in Jupiter, Dynaudio’s world-class measuring facility, and tuned by the same ears behind some of its most prestigious loudspeakers.
Clean Scandinavian design
Danish design is a synonym for ‘desirable’, and Focus is no exception. Its slim cabinets, available in four beautiful contemporary finishes (White High Gloss, Black High Gloss, Walnut Wood and Blonde Wood), are designed to blend in with real-life interior decor for those who’d rather not re-arrange their living-room around their speakers, or be distracted from their music or films by something that looks too outlandish.
Even the Dynaudio logo has been simplified, doubling as an integrated LED that tells you at a glance what the speaker is doing.
Outstanding craftmanship
Of course, Focus wouldn’t be a proper Dynaudio speaker if its build quality wasn’t jaw-dropping. Sturdy MDF cabinets, a long-life amp design and premium touches such as aluminium driver surrounds make it obvious that you own a high-end product.
No, absolutely not.
This is an active reduction of bass extension EQ, build in on purpose. KEF invented a name for it, iBX = intelligent bass extension. The basic idea is that at high or very high volumes the lowest bass will not be missed that much. They actively use a psychoacoustic effect here. It's not compression that "just happens" because the speaker can't go any louder.
They limit the little guy because it can’t produce low bass anyway. I’m all for the approach, it means the drivers are optimized to give everything they’ve got but never pushed past their limit, but KEF wouldn’t do it if they didn’t have to.
Very true. And let's not forget: 111 dB max. SPL at 1 m is still pretty hefty for such a small speaker. By chance it exactly equals the R7 in that respect (and clearly beats LS50 Wireless II, of course).
One could argue that there is some trickery involved because bass EQ is reduced at higher levels. This is true as well, but it's very clever trickery and few people will even notice, if they didn't read the white paper.
But this is what engineering has done, right, not marketing. You can certainly argue that terms like iBX are marketing speech (like MAT, SAS, SDCT, even Uni-Q and Uni-Core or GLM, Iso-Pod, SAM, The Ones, you name it). At least everything technical that actually performs a specific function will need a name anyway, be it marketing driven or not.I’m all for the approach, it means the drivers are optimized to give everything they’ve got but never pushed past their limit, but KEF wouldn’t do it if they didn’t have to.
Indeed. It's funny in interviews when Jack Oclee-Brown has to talk about those things and he struggles to remember what marketing decided to call them, because it's not what they called them during years of development - they're labels stuck on after the event. He can at least remember the big ones like Uni-Q and (now) Uni-Core.You can certainly argue that terms like iBX are marketing speech
Active bass EQ is such a thing. A -3 dB point of 31 Hz would be absolutely impossible to achieve from a 12.3 l cabinet without EQ, that's physics. 108 dB SPL (111 dB -3 dB) at 31 Hz would be absolutely impossible using four 5,25" woofers even with EQ, that's physics as well. Finding a solution that allows full bass extension at most typical listening levels and degrades this extension gracefully in the case of higher levels is a fine example of engineering balancing conflicting targets in my book. It's a compromise made under the boundary condition that small size has highest priority.
Users demanding full bass extension at extremely high levels will have to add one or two subwoofers. LS60 Wireless allows to do that in a technically good way by including a HPF and runtime correction. Isn't that a solution we can all live with?
Since you mention the KC62 I can see users combining it with LS60s due to its small footprint. That would not be my preferred choice in this scenario. But that's a different topic.
What I’m saying is that the laws of physics give them no choice in the matter
Well, the KC92 are also there...But this is what engineering has done, right, not marketing. You can certainly argue that terms like iBX are marketing speech (like MAT, SAS, SDCT, even Uni-Q and Uni-Core or GLM, Iso-Pod, SAM, The Ones, you name it). At least everything technical that actually performs a specific function will need a name anyway, be it marketing driven or not.
Yes. Tested both as I like the small form factor, but the KC62 struggles with larger rooms. Therefore I also bought the KF92 (two actually) (The KF92 is still small by comparison with all the pros and cons).Yes, everything is smaller than their other speakers.
Which still exist, and don't need the same sort of fancy electronic shenanigans to work within their constraints.
I'm sure you'll see some of the tech filter through to larger sizes at some point though.
I didn't bemoan how compromised the KEF KC62 was by its size, I just acknowledged the engineering smarts, decided it wasn't for me and bought the bigger KF92 instead.
that has nothing to do with investors/marketing. it was a design goalThe LS60 seems to be compromised in many regards because of the investors/marketings insistence on having a thin speaker.
you're saying that like it's a bad thing. it keeps great directivity while increasing dispersion. what's wrong with people?The tweeter is smaller. The mid is smaller.
that's the only legitimate concernWould be a shame if any of the electronics would die after 5 years.
Dictated by marketing. An engineer would have choosen a speaker that is a few mm less slim.that has nothing to do with investors/marketing. it was a design goal
Consider why almost all good tweeters are about 1 inch. Now ponder why this one is smaller and why that tradeoff was made.you're saying that like it's a bad thing. it keeps great directivity while increasing dispersion. what's wrong with people?
Sorry, but that's historically proven nonsense.Consider why almost all good tweeters are about 1 inch.
Isn’t Uni-Core directly addressing ‘no replacement for displacement’ through the different sized voice coils to get higher excursion? On top of the use of multiple cones to increase area? Because last I checked, displacement is measured as a volume, not as two dimensions (I’m not aiming this at you, by the way).Gosh, we get it - some of you think there is "no replacement for displacement" and aren't open to understanding the science here or reading the white paper. That's fine, move on. Also please stop bemoaning speakers designed with DSP being necessary as not having a passive option. DSP enables this speaker to exist and perform well. If you don't like it - Kef has plenty of other speakers for you... This is something different that doesn't exist in the market today. Kef should be praised for taking bold steps and doing something different.
