KEF LS50 Metas - dips around 3 & 6 kHz on both speakers - fault or am I measuring wrong?
So BOTH speakers are showing very weird cancellations consistently and no one bothered to ask if the Microphone is the culprit?
Completely valid comment, but to be fair the mic is working fine, it was some unexpected DSP on the computer causing this. The comments saying it looked like some kind of acoustic cancellation were half right, I guess.
The fact that it looked like some kind of DSP (not the mic) was picked up on pretty quickly, even if the source of the DSP was not worked out. Always nice to have someone come in after the problem was found to criticize everyone trying to help for not running it down faster, I guess.
Lmfao point taken. It’s just it’s extremely unlikely that both speakers got blown/are broken without some serious misuse.
It all ended well and the OP got 2 un-dented new drivers!
Looking at the second measurement in post #52, the sudden jog in the phase response between 7kHz and 8kHz is strange. Perhaps something is dropping samples sporadically? Do you hear any clicks or other abnormalities when playing the sweep from REW on your MacBook?
I redid the RoomFIt on the Wiim Ultra and getting this now. I used the moving mic method.
I don't hear anything, but wasn't specifically listening out for it either.
I also think a measurement of both speakers right away (instead of doing it after the drivers were exchanged) would have ruled a driver / XO fault out from the start. It also shows us again that AI is not particularly helpful if you dont know what you are doing.
Both speakers were measured before the drivers were replaced, and the REW files were saved for reference. A Bluetooth speaker was also measured as a check to make sure the measuring equipment wasn’t at fault.
It wasn’t until after I got them back that I thought to play the sine sweep from a different source when someone mentioned they’d seen something similar with echo suppression.
Where do you think AI was mis-leading the process?
I still don’t really know what’s causing the erroneous results, so if you have any ideas that, then gratefully received. I’m using a eversolo em-1 mic, and considering purchasing a UMIK instead to see if that works better.
Maybe I didnt see it but I only saw a measurement of two speakers after the driver was replaced. What Gemini said about the impulse response was not wrong. But also not helpful. Anyway the fact that both of the speakers showed the same issue was the important information here. This is also why I always try another speaker when I measure something strange.
I think it was a valid (but ultimately proven wrong, luckily) hypothesis that the OP could very well have blown both tweeters by doing the same high power sweep (exceeding the max tweeter power) to both speakers. ("Don't look at laser with remaining good eye.")
So, could somebody explain what in the setup caused REW to see those dips in the frequency response? Filters applied to the sound output at the (MacBook ?) system level?
The precise cause is yet to be determined unless @riiich88 figured it out in the last few days.
It’s still a mystery. I’m away from home for a couple of weeks but when I get back I’ll see if I can measure my friends ls50s and see if I get the same issue. The are the wireless version but should tel me something.
