I bought KEF LS50 Metas a while back, but never quite fully engaged with them. I recently started experimenting with them (swapped amp, got a wiim ultra). Then in the process of adding a sub, I measured them this weekend and there's a big dip around 3 kHz on both speakers. Smaller ones again around 6 kHz and 9 kHz. My wife also pointed out the vocals sounded recessed, and I thought that listing to Netflix through them, the vocal sounded thin. I can't say though if this is something that's been there from new or has crept in.
Things I've tried, none of them changed it:
- moved the speakers forward, more toe in
- took the coffee table out
- blanket under the speaker, blanket around the mic
- speaker on the rug, off the stands
- measured at 20 cm, 1 m and 2.8 m
- mic pointing up and pointing at the speaker
- left and right on their own - same on both
- swapped the Nord amp for an old valve amp - same
- swapped the WiiM for a different DAC - same
- all EQ off, sub off
Then I put a Bose Bluetooth speaker in exactly the same spot with the same mic. Smooth through all three, no dips.
Blue is the KEF, pink is the Bose.
Mic is an EM-01 with the cal file loaded. SPL isn't calibrated so ignore the absolute numbers, I'm only looking at the shape.
So either I'm making a beginner mistake I can't see, or something is wrong with both speakers. Any ideas?
Best,
Rich
