KEF LS50 Metas - dips around 3 & 6 kHz on both speakers - fault or am I measuring wrong?
Tweeters that are blown usually make no noise at all; ....
Or the tweeter is semi-functional:
Gemini AI
I contacted the service centre and will take them in next week. Warranty on the drivers is 5yrs, electronics 2yrs. I bought mine in 2022 so hoping it’s the drivers and they overlook a couple of toddler dings on them! Will post back on how I get on.
I took the driver out of one speaker and had a look - nothing smelly or burnt looking. It scratched the paint on the way out and was a pain to reseat so reluctant to do too much poking about inside whilst still a chance of warranty cover. Might give the outside test ago, although it’s not completely open space. The Bluetooth speaker tested fine so don’t think something off with the mic.
If I were you, I wouldn't mess with the drivers, since you mentioned that you still have a valid warranty.
My suggestions for checking and examining the unit (unscrewing the drivers) were based on the assumption that there was no warranty.
riiich88 might have blown both tweeters during a high-volume listening session. It’s not exactly uncommon for speakers to get blown out when listening at high volumes.
Have they always sounded the way you described?
Sorry, I missed what you said:...but never quite fully engaged with them.
Did you buy them new or used?
(The previous owner might have blown the tweeters.)
Bought new in 2022 after trying a number of different speakers in different shops (other than some Harbeths (which sounded amazing but out of budget), I forget which ones).
Hard to pinpoint what wasn't connecting - some music sounded good others not so much and I put it down to the quality of the recordings.
Recently after moving house, and listening properly for the 1st time in a while, I decided to look further into it and ended up down a rabbit hole that involved a replacing PrimaLuna Prologue One with a Nord One MP NC252, then a Wiim Ultra in place of a Node 2i/Beresford Caiman combo (my records always sounded better than the Node), and a sub (KEF R400). Plus of course: REW, a mic and some blind A/B testing by my wife.
And so here I am, a few $100s lighter in the pocket, some dodgy LS50s and one eye on some used Harbeths.
I thought they would be well out of warranty too until I checked this morning - will resist further peeking.
...some dodgy LS50s....
But if they work as intended, they seem to be good speakers:
They aren't really meant for playing at high volumes, and pairing them with a subwoofer (as you are doing) is pretty much a must.
....and one eye on some used Harbeths.
Harbeth speakers have a classic, old-school look. Otherwise, if you want something with a classic two-way bookshelf speaker aesthetic that is a bit cheaper than Harbeth but still good, there is:
That applies if you live in the US; otherwise, shipping costs could make it complicated and expensive.
One more tip. These have become popular:
Yes, I think they are and that I’ve not had them setup right regardless of current issues.
There’s a certain appeal to having a pair of old school style speakers with a valve amp and record player on the console, but I want to get KEFs fixed, working well with a sub-woofer, and get the wiim room eq setup nicely, before doing anything else. I don’t often listen at high volumes anyway so no issue there.
Thanks for the speaker recommendations - I will take a look at them.
There’s a certain appeal to having a pair of old school style speakers with a valve amp ....
...that pair well together—I probably should have added that.:)
"Pair well"—meaning reasonably high sensitivity, and speakers that are an easy load for a tube amp (i.e., a high and steady impedance curve, without troublesome dips or wild fluctuations).
And good speakers that meet those tube amp requirements aren't exactly plentiful.
Use speakers that feature bi-amping capabilities. Let a Class D amp handle the bass, thereby relieving the tube amp of bass duties. A low-power tube amp driving the tweeter—or the midrange and tweeter—could work. However, the balance between low power and the sensitivity of the midrange/tweeter drivers remains a factor to consider.
I suspect that tube purists would consider suggesting a hybrid solution like that sacrilege, but still.
By the way, that is the only sensible use I can see for the bi-amping function on speakers equipped with it.
Interesting idea. Guess would need a preamp that handle crossover.
Crossovers come in many flavors but that is rarely the job of "a preamp" (line gain and source switching) even those that offer tone controls or DSP based PEQ, loudness contour etc
Some ways of doing active crossovers may also offer some of those functions "act as a preamp" maybe DDC / ADC / DAC format conversion as well.
What you need to do is plug an RCA splitter into the WiiM Ultra's output:
Run cables from there to two amplifiers equipped with volume controls. Connect those to the bi-amp terminals on the speakers. Listen and set the appropriate volume level on each amplifier. Then, control the master volume using your WiiM Ultra.
Active crossovers are a thing
In the case of speakers with bi-amping capability, passive crossovers for the respective drivers are already built into the speakers. This simply provides a way to power them separately using dedicated amplifiers.
In most cases, bi-amping is an unnecessary feature.
Speakers that lack passive crossovers and instead use active or digital crossovers—that is a different matter entirely. Speakers with built-in amps and DSP. In other words, active speakers. That could be a good option for the TS, provided he doesn't want to use the amplifiers he currently owns.
Many people convert to bi/tri-amp, also active bypassing the built in passive xovers.
I was just responding to the specific text I quoted
Note that Wiim Ultra can also now output RCA analog **concurrently** with either S/PDIF pair
That is certainly a possibility—especially if you want to venture into the DIY sphere and experiment a bit.
Come to think of it, since the topic of tube amps has come up: DIY offers opportunities to build speakers that are reasonably high-sensitivity and tube-" load friendly". You can tailor-make speakers you want—the kind of speakers that aren't exactly abundant on the commercial market.
I’m not really a tube dude myself, so I’m just guessing, but there ought to be speaker projects like that on DIY forums—perhaps even in ASR’s own DIY section. They might not be flooded with DIY speaker projects specifically suited for tube amps, but there should be a few out there.
Yes very active helpful communities, great design tools available.
No need to lead with explicitly advertising the tubes aspect, so long as you know the component attributes you are looking for.
I would love to do this one day, but so little free time at the moment with kids.
Anyway. For some reason I decided to ask Gemini about it rather than using Claude like I usually do, and it got me to generate 3 graphs. It seems to think the phase is inverted 180 deg, and is a fault from the factory.
  • Impulse Response (IR): The initial high-frequency arrival spike went downward (-100%) first instead of upward (+), showing that the tweeter cone moves inward when given a positive voltage signal.
  • Phase Graph: The measured phase line wraps by 180° precisely at each frequency dip, while the theoretical minimum phase line remains smooth.
View attachment 559176View attachment 559170
Build this with the kids (if they’re at the Lego-playing age):
But since you bought your KEF LS50 Meta speakers new, no one else has—for whatever reason—tampered with the cables connected to the coaxial driver and accidentally reversed the polarity.
It’s a long shot, but stranger things have happened: the manufacturer might have wired them incorrectly. Unscrew the coaxial driver and check. While you're at it, take the opportunity to measure the driver with a multimeter.
By the way, incorrect polarity can cause a dip at the crossover frequency of 2.1 kHz, but since you also have a dip at 6 kHz, that’s unlikely to be the cause in this case. At least that’s what I think—though others can correct me if I’m wrong about that assumption.
