alitomr1979
- Joined
- Aug 15, 2021
- Messages
- 144
- Likes
- 72
Check to see if your Denon receiver has preamp outputs, which it should if if is a mid line unit.I appreciate you sharing all this info I’ll take firsthand experience with the product all day which you have plenty of, so much appreciated! Would I be able to plug the CXA61 into my Denon s760h?
What would be inconvenient and the main reason I wanted an upgrade (probably how I rationalized it) was because of the inconvenience of not having home theater bypass, which is a feature of some high-endish integrated amps with which you get to use one or more of its inputs as power amps, meaning you bypass the internal preamp of the integrated amplifier and can control the volume with the source, in this case your Denon receiver. The inconvenience is that you have to put the CXA61 at certain volume level (high) and calibrate/run room correction with it at one specific level. If you listen to music using other sources than your Denon as a source/DAC, which you will find you need after you listen to a another better stereo DAC, you won’t be listening to those other sources at such high level, or even at that fixed level, which means you will have to put the CXA61 to the exact same volume level when you go back to using your receiver. A little inconvenient but it can definitely be done.
My options were the Peachtree Nova 300 and Musical Fidelity M5si, and after finding out about the new and supposedly improved Amp500, I thought I could do better with separates, Amp500, a really good and praised DAC as the SMSL M400 and the Topping Pre90 as preamp. As you know I much preferred this combo to the M5si and against all other combos I managed to arrange during the weekend with equipment we had available (check my previous post in this thread).
Going back to your original question, I came back home and tested the new equipment with the R3s. I did not remove the dual subwoofer though.
My impressions: the Cambridge CXA81 IS A HELL OF AN AMP. I tried the M400 DAC with it and was impressed. Then I went with the new equipment and the first couple songs didn’t make anything outstanding and I noticed the slightly more clear and less meaty presentation of a the Amp500. But then a few high res songs started playing and I did notice how relaxed everything sounded and how the vocals were way more clear, bass notes, and crazy details especially of instruments’ decaying notes. Something really special was listening to Melody Gardot’s live “Deep within the corners of my mind”. At the beginning there is a Cello solo that is impressive and in the end of it there’s details I’ve never heard before. It was really something.
R3 vs LS50 metas. Really tough one. The metas I think definitely have a little more transparency. Or Maybe?. I don’t know if the much bigger and louder bass being produced by my two subs is masking the mids and highs a bit. Where the R3 take the cake easily is where it comes to presence. The sound is way more imposing. The Metas I think have better soundstage and probably instruments are a little easier to distinguish in an specific place.
If you are rocking and pushing the speakers the R3 are the way to go even though the metas seemed to me very improved compared to the OG LS50 when it comes to playing loud. The OGs lose composure rather early when it comes to playing loud, imho, which is one of the two reasons because I don’t think they are simply perfect (second is not being very dynamic).
You really can’t go wrong with neither. With both a subwoofer (or two to be setup in stereo, preferably) is going to take the experience to another level. The improvements in the metas are there. Are they better than the R3s? I think in some aspects. Overall it is still a too close to call, imho.
I hope I’ve been able to communicate some of the difference and help you with your decision.
